I am having trouble login while trying to install omniverse launcher. It pops out the website but after I log in, the omniverse launcher does not log in at all. I am installing omniverse to a shared server, where other has installed omniverse in the account.
Thank you!
Here is the trace of the error, I wonder what is going wrong.
16:57:12.292 › Omniverse Launcher 1.8.3 (production)
16:57:12.299 › Argv: /tmp/.mount_omnivebAK3Sr/omniverse-launcher
16:57:12.299 › Crash dumps directory: /home/username/.config/omniverse-launcher/Crashpad
16:57:12.411 › Reset current installer.
16:57:12.414 › Can’t access the /home/username/.nvidia-omniverse/config/privacy.toml file: ENOENT: no such file or directory, access ‘/home/username/.nvidia-omniverse/config/privacy.toml’
16:57:12.416 › Running production web server.
16:57:12.426 › Failed to start the Launcher API: Error: listen EADDRINUSE: address already in use 127.0.0.1:33480
at Server.setupListenHandle [as _listen2] (node:net:1372:16)
at listenInCluster (node:net:1420:12)
at GetAddrInfoReqWrap.doListen [as callback] (node:net:1559:7)
at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:73:8)
16:57:12.429 › Sharing: false
16:57:12.478 › Failed to start the Navigator web server: Error: listen EADDRINUSE: address already in use 127.0.0.1:34080
at doListen (node:net:1559:7)
at process.processTicksAndRejections (node:internal/process/task_queues:84:21)
16:57:13.098 › Saving omniverse-launcher.desktop file to /tmp/omniverse-launcher-U2Jzcs…
16:57:13.098 ›
[Desktop Entry]
Name=omniverse-launcher
Exec=“/home/username/Desktop/omoni/omniverse-launcher-linux.AppImage” --no-sandbox %u
Type=Application
Terminal=false
MimeType=x-scheme-handler/omniverse-launcher
16:57:13.149 › Saving omniverse.desktop file to /tmp/omniverse-launcher-NohPcs…
16:57:13.150 ›
[Desktop Entry]
Type=Application
Terminal=false
^C
