Hello Nvidia forums,
we are adapting our Xavier-based PCB for Orin usage and there is a slight problem with pins that were in Xavier AGX designated as C4.
One of the PCIE interfaces (Mini-PCIE) is connected to C4, and was working in the Xavier AGX without any problems. However, there seems to be a difference in the pinout between Xavier and Orin. This problem is further exacerbated by the fact that the C7 (lanes 0,1,2,3 and its appropriate clkreq+rst) is already in use for another interface (M2 drive slot). In the below table you can see pins used for the Mini-PCIE, which refuses to show up in the lspci listing (did I compile this data correctly, or is my line of thinking wrong?):
| pin # | xavier name | orin name | comment |
| A14 | PEX4_RX0N | PEX7_RX6N | mismatch |
| A15 | PEX4_RX0P | PEX7_RX6P | mismatch |
| C14 | PEX4_RX1N | PEX7_RX7N | mismatch |
| C15 | PEX4_RX1P | PEX7_RX7P | mismatch |
| J15 | PEX4_TX0N | PEX7_TX6N | mismatch |
| J14 | PEX4_TX0P | PEX7_TX6P | mismatch |
| G14 | PEX4_TX1N | PEX7_TX7N | mismatch |
| G15 | PEX4_TX1P | PEX7_TX7P | mismatch |
| E22 | PEX_CLK_OUT_4_N | PEX_CLK_OUT_4_N | |
| E23 | PEX_CLK_OUT_4_P | PEX_CLK_OUT_4_P | |
| G8 | PE4_CLKREQ_L | PE4_CLKREQ_L | |
| J9 | PE4_RST_L | PE4_RST_L |
The above table contains pin # and the pin names as from the Pinmux Spreadsheet.
Below is my config for the C4 and C7. C4 is wired to the problematic interface.
// PCIE C4 CONFIG ===========================================================
pex_l4_clkreq_n_pl0 {
nvidia,pins = "pex_l4_clkreq_n_pl0";
nvidia,function = "pe4";
nvidia,pull = <TEGRA_PIN_PULL_NONE>;
nvidia,tristate = <TEGRA_PIN_DISABLE>;
nvidia,enable-input = <TEGRA_PIN_ENABLE>;
nvidia,io-high-voltage = <TEGRA_PIN_ENABLE>;
nvidia,lpdr = <TEGRA_PIN_DISABLE>;
pex_l4_rst_n_pl1 {
nvidia,pins = "pex_l4_rst_n_pl1";
nvidia,enable-input = <TEGRA_PIN_DISABLE>;
// PCIE C7 CONFIG ================
pex_l7_clkreq_n_pag0 {
nvidia,pins = "pex_l7_clkreq_n_pag0";
nvidia,function = "pe7";
pex_l7_rst_n_pag1 {
nvidia,pins = "pex_l7_rst_n_pag1";
My device-tree config, I tried to somehow force the mismatched pins into the pcie@14160000 node:
// Mini-PCIE, C4 ROOT PORT x2
pcie@14160000 {
status = "okay";
// phys = <&p2u_hsio_4>, <&p2u_hsio_5>;//, <&p2u_hsio_6>, <&p2u_hsio_7>;
phys = <&p2u_gbe_6>, <&p2u_gbe_7>; // Orin: C7 vs C4??
phy-names = "p2u-0", "p2u-1";//, "p2u-2", "p2u-3";
num-lanes = <2>;
nvidia,disable-power-down;
// max-link-speed = <1>; // Optional
// M.2, C7 ROOT PORT x4
pcie@141e0000 {
status = "okay";
num-lanes = <4>;
phys = <&p2u_gbe_0>, <&p2u_gbe_1>, <&p2u_gbe_2>, <&p2u_gbe_3>;//, <&p2u_gbe_4>, <&p2u_gbe_5>, <&p2u_gbe_6>, <&p2u_gbe_7>;
phy-names = "p2u-0", "p2u-1", "p2u-2", "p2u-3";//, "p2u-4", "p2u-5", "p2u-6", "p2u-7";
As you can see C7 lanes (0,1,2,3) are already taken by pcie@141e0000, and AFAIK I cannot just assign phys = <&p2u_gbe_6>, <&p2u_gbe_7>; to pcie@14160000.
My lspci output:
nvidia@orin:~$ lspci
0000:00:00.0 PCI bridge: NVIDIA Corporation Device 229c (rev a1)
0001:00:00.0 PCI bridge: NVIDIA Corporation Device 229e (rev a1)
0004:00:00.0 PCI bridge: NVIDIA Corporation Device 229c (rev a1)
0007:00:00.0 PCI bridge: NVIDIA Corporation Device 229a (rev a1)
0007:01:00.0 Non-Volatile memory controller: ADATA Technology Co., Ltd. XPG SX8200 Pro PCIe Gen3x4 M.2 2280 Solid State Drive (rev 03)
Is my line of reasoning correct, is there a pin mismatch?
If yes, is there a way to re-use idle C7 lanes in another interface?
Best regards,
Jerry
