Orin Nano USB Ports
Try other cable or other host.
I guess it was a faulty cable. Used an arduino as the USB to Serial converter. Here’s the output.
jetson_log.txt (102.7 KB)
Could you share the log based on jp5.1.2 instead of jp6?
Also, please just use default image, I don’t want to see something like camera IMX219 thing got enabled there.
Here’s the logs for jp5.1.2
jetson_log.txt (100.3 KB)
This is still jetpack6 log… are you sure you know how to flash?
jetson_5.1.2_log.txt (85.9 KB)
I made sure it flashed 5.1.2 this time.
Could you connect any usb device like mouse or keyboard to your jetson and see if dmesg has anything new printed?
No. None of the USB ports work.
If this is NVIDIA developer kit, please RMA.
