Assuming the cameras do not exceed the bandwidth of the csi is the below configuration possible on the Orin NX 16Gb? All cameras need to stream simultaneously.
Where the aggregator is a GMSL MAX96724 and the cameras are utilizing virtual channels and the isp.
yes, please be aware that each data lane has a peak bandwidth of up to 2.5Gbps.
let me give you an example to calculate CSI date rate for quick checking.
for instance, 4K (3840x2160), 90-fps, 10-bits per pixel. (i.e. Raw10) CSI data-rate = 3840 * 2160 * 10 * 90 * 1.15 ~= 8.584 Gbps
