Ouster OS1-128 multicast not working
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
Two Ouster OS1-128 lidars, currently configured to multicast gives a timeout error when called on the Orin.
The lidars are connected to a switch, which is connected to mgbe0_0 Ethernet interface of the Orin.
ifconfig shows that the port supports multi cast.
Ping works. So we know that the Orin can see the sensors.
Two other generic Linux PCs are also connected to the switch. When the Ouster lidars are called there, both PCs can see and use the lidar data, simultaneously.
Our use case requires the Orin and one of the PCs to use the lidar data simultaneously, due to timing constraints.
Error String
< Please provide just the error messages here >
Logs
Provide logs in text box instead of image
Please paste the complete application log here. If there are multiple logs, please use multiple text box
Dear @adityen.sudhakaran ,
I notice OS1 128 is not listed in supported sensor list at DRIVE AGX Orin Sensors & Accessories | NVIDIA Developer . Are you using DW to capture the data?
No, DW is not being used to bring the sensor up. The official Ouster ROS2 node is running inside a docker container.
