Please confirm pinout for A2B
DRIVE OS Version: 7.2.5
Issue Description:
I would like a confirmation of the pinout on the Drive AGX vehicle harness.
Here, it seems that A2B 1 Port A should be connected to VH-1 P7 Pins 38/39.
A²B Interfaces — NVIDIA DriveOS 7.2.5 Linux SDK Early Access Developer Guide
But in the Hardware Mechanical Gude found here those pins are labeled as RESERVED.
NVIDIA DRIVE Documentation | NVIDIA Developer
Is the documentation in the Developer Guide Correct, I.e.
Are these the correct connections for A²B1 Port A
VH1 - P7
A²B_P - 4 38
A²B_N - 5 39
Thanks and Regards,
Jacob
Dear @jacob.hartzell.fe ,
Let me check on this internally and update you.
May I know your use case?
Yes, those pins allow for the dev kit to sit in the middle or end of an A2B network.
The pin info is Mechanical installation guide is correct. We will update the DOS developer guide. Thanks
