Hello Nvidia team:
Jetpack Version:5.1.1
I want to bring up a gmsl(max96712 + 4x max96705) cam on JESON AGX ORIN, after gmsl init i use below command to preview video:
gst-launch-1.0 v4l2src device=/dev/video1 ! xvimagesink -ev
But i just can view first frame on screen, not continuous video output on screen.
Below is err info of dmesg&trace, Can you help me analyze the reason?
By the way , our camera is YUV format, our config:
mclk_khz = "24000";
num_lanes = "4";
vc_id = "3";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
dynamic_pixel_bit_depth = "16";
csi_pixel_bit_depth = "16";
mode_type = "yuv";
pixel_phase = "uyvy";
active_w = "1280";
active_h = "720";
readout_orientation = "0";
line_length = "1280";
inherent_gain = "1";
pix_clk_hz = "300000000";
serdes_pix_clk_hz = "300000000";
dmesg err info:
[ 9022.200745] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 9022.234078] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 9022.267412] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 9022.300756] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
trace err log:
jetson_agx_orin_2023-08-14_16-29-03.log (526.9 KB)
