Xavier NX is powered by 5V, just as Jetson Nano.
How many Amps do I have to reserve on the 5V rail for the module?
Hi, the general power is 10W ~ 15W, you can get the current accordingly.
Can I have power supply suggestions for jetson xavier NX development kit? also ensuring maximum power utility!
Hi @krisha.sundar19, the Jetson Xavier NX Developer Kit already includes a power supply - it’s a 19.5V brick. The devkit supports between 9-20V, which is regulated down to 5V on the devkit’s carrier board.
@dusty_nv I think wifi card also included by default! Thanks!!
Yes, that is correct - the NX devkit comes with an M.2 Key-E 2x2 802.11ac + Bluetooth 5.0 module. It’s an AzureWave AW-CB375NF using the Realtek RTL8211 chipset.
Thank you so much @dusty_nv , this would be very successful product !!
@dusty_nv hey the power brick input also suits 220V right ? I am from india , should be universal if i am right!
Are you sure AzureWave AW-CB375NF is using the Realtek RTL8211 chipset because it looks like the RTL8211 is the chipset for ethernet transceivers?
I plugged it @220v without even looking at it, so yes :)
Thanks for info!
