I’ve really tried hard to try everything I could think of before coming here. nvidia-bug-report will be attached after I create the topic. Things I’ve done so far:
Secure boot is disabled
I installed via apt, and it was successful, but nvidia-smi says it cannot communicate with the driver.
Purged the apt driver and tried installing it from .run file. Same issue.
Ran the .run file with --uninstall and went back to the apt install. No change.
Tried installing nvidia prime and prime-select nvidia. No change.
Tried blacklisting with blacklist-nvidia-nouveau.conf. No change.
It’s a dual-boot Ubuntu/Win 10 machine. Very few customizations on the Ubuntu side – though I am using the Unity Desktop as my display manager (not sure if that matters).
The log shows some kernel compilation errors, but before I start poking around in the kernel I figured I’d come here. nvidia-bug-report.log.gz (115 KB)
Please don’t use the .run installer, it’s an Optimus system.
Currently, there’s no kernel driver installed, please reinstall the driver from repo
sudo apt install --reinstall nvidia-driver-430
Afterwards,
make sure nvidia-prime is installed (sudo apt install nvidia-prime)
Please run
sudo dkms install nvidia/430.26 --all
and check dkms status afterwards that the status changed from built to installed for the currently running kernel.
Both show installed now, and nvidia-smi worked. However, when I rebooted, it froze after entering my password. I opened up a terminal with Ctrl+Alt+F3 and prime-selected intel just to unfreeze it. I then tried re-running the reinstall commands from earlier: no change in behaviour.
This is more progress than I’ve made in many days though! Thanks already for helping!
miketwo@miketwo-acer:~$ dkms status
nvidia, 430.26, 4.15.0-64-generic, x86_64: installed
nvidia, 430.26, 4.15.0-65-generic, x86_64: installed
miketwo@miketwo-acer:~$ nvidia-smi
Mon Oct 14 19:08:09 2019
| NVIDIA-SMI 430.26 Driver Version: 430.26 CUDA Version: 10.2 |
| 0 GeForce GTX 1060 Off | 00000000:01:00.0 Off | N/A |
| N/A 53C P0 27W / N/A | 0MiB / 6078MiB | 2% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
miketwo@miketwo-acer:~$ nvidia-settings
ERROR: Error querying enabled displays on GPU 0 (Missing Extension).
ERROR: Error querying connected displays on GPU 0 (Missing Extension).
** Message: 19:08:14.974: PRIME: Requires offloading
** Message: 19:08:14.974: PRIME: is it supported? yes
ERROR: nvidia-settings could not find the registry key file. This file should have been
installed along with this driver at
/usr/share/nvidia/nvidia-application-profiles-key-documentation. The application
profiles will continue to work, but values cannot be prepopulated or validated, and
will not be listed in the help text. Please see the README for possible values and
descriptions.
Outstanding success! That was the final brick in the wall.
I still get a strange error on login (something about xrandr not find eDP-1), but it logs me in properly and nvidia-setting and -smi both work! The glmark2 benchmark is also showing numbers that indicate it’s using the right card.
Thanks so much!!!
Now I just need to install nvidia-docker, but I can probably handle that part on my own.
