Quick question…i am following along with the instructions from GitHub - dusty-nv/jetson-reinforcement: Deep reinforcement learning GPU libraries for NVIDIA Jetson TX1/TX2 with PyTorch, OpenAI Gym, and Gazebo robotics simulator.
to install the project on the jetson tx2. However the installation doesn’t complete, instead it keeps ended with errors.
Does anyone know if it only runs on a certain version of linux? I installed the latest one 18.04 and its not working? Any insight would be much appreciated. Also i am using jetpack 4.2.2 Does the project only work on jetpack 3.3?
Hi camransyed, the RL code from that is using PyTorch v0.3.0 and Gazebo7, and needs JetPack 3.3 - sorry about that.
Thanks Dusty! Where can i get information with regards to downgrading from Jetpack 4.2 to 3.3?
If you download NVIDIA SDK Manager to your host PC, you can re-flash your TX2 with JetPack 3.3.1. On the “Step 01” screen, click the … at the bottom right of the “Target Operating System” box, then click “show all versions”, and you will be able to select JetPack 3.3.1.
hi Dusty! I followed your advice and re-flashed to jetpack3.3.1.
However upon the “make” step in your instructions ( GitHub - dusty-nv/jetson-reinforcement: Deep reinforcement learning GPU libraries for NVIDIA Jetson TX1/TX2 with PyTorch, OpenAI Gym, and Gazebo robotics simulator.)
I get this error:
ubuntu@jetson-0420219087068:~/RoboND-DeepRL-Project/build$ make
[ 38%] Built target jetson-utils
[ 40%] Building CXX object CMakeFiles/jetson-reinforcement.dir/c/rlAgent.cpp.o
In file included from /home/ubuntu/RoboND-DeepRL-Project/c/rlAgent.cpp:6:0:
/home/ubuntu/RoboND-DeepRL-Project/c/pyTorch.h:14:19: fatal error: TH/TH.h: No such file or directory
compilation terminated.
CMakeFiles/jetson-reinforcement.dir/build.make:227: recipe for target ‘CMakeFiles/jetson-reinforcement.dir/c/rlAgent.cpp.o’ failed
make[2]: *** [CMakeFiles/jetson-reinforcement.dir/c/rlAgent.cpp.o] Error 1
CMakeFiles/Makefile2:67: recipe for target ‘CMakeFiles/jetson-reinforcement.dir/all’ failed
make[1]: *** [CMakeFiles/jetson-reinforcement.dir/all] Error 2
Makefile:83: recipe for target ‘all’ failed
make: *** [all] Error 2
It seems that there is a problem with pytorch? What might be the fix?
