My PC has windows 10 and Visual Studio 2015.
I have installed PVF 18.7 and PVF 18.10. The installation was successful but I have error when compiling my program with Full Debug. The program is created successfully with disabled Debug.
I am thinking maybe I can try Windows command line compiler. Is it possible to install both PVF and command line compiler on my PC?
Giang
Yes, and it’s already there. From the start menu, select “PVF for VS 2015 cmd” from the PGI Visual Fortran drop down to open a DOS command Window with the compiler paths set. You can also manually configure a DOS command window.
PVF doesn’t come with Cygwin, so you wont have the nice Linux utilities such as make. But you can either download the PGI Workstation command compilers to get Cygwin or install Cygwin separately. The compilers are the same between the PVF and Workstation, it only the interface to the compilers that’s different.
-Mat
