Hello!
I recently set up my PC for duel-booting, until i decide if i wish to go full Linux.
So far, I’ve install what i believe are the right drivers for my graphics card. I’ve made changes suggested by other boards as well, but i still experience slow down on the OS when with Windows 10 i never experienced.
I most likely either haven’t gotten everything set-up or i messed something up, so if anyone is more experienced on setting up drivers for KDE Plasma I’d greatly appreciate it
Spec details:
Allocated RAM (for linux boot): 32gbs
Distro: Ubuntu 22.04.1 LTS
Graphics Card: NVIDIA GeForce RTX 2060 Rev. Asus Edition
OpenGL Version: 4.6.0 NVIDIA 515.48.07
If anyone has suggestions or potential solutions please let me know!
Thank you
nvidia-bug-report.log (529.8 KB)
Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post.
Your 2TB seagate hdd is broken, should be replaced. Furthermore, the nvidia driver was updated so you need to reboot, it’s defunct right now.
My linux distro is set up on a partition not located on my HHD. Does that still mean i have to change it out?
Which part inside of that log file tells you that my HHD is broken?
If the data on it isn’t important, you can keep using it until it breaks completely, of course.
dmesg
1781.933007] ata1.00: exception Emask 0x0 SAct 0x100000 SErr 0x0 action 0x0
[ 1781.933027] ata1.00: irq_stat 0x40000008
[ 1781.933035] ata1.00: failed command: READ FPDMA QUEUED
[ 1781.933041] ata1.00: cmd 60/80:a0:00:47:84/00:00:dc:00:00/40 tag 20 ncq dma 65536 in
res 43/40:80:30:47:84/00:00:dc:00:00/00 Emask 0x409 (media error) <F>
[ 1781.933061] ata1.00: status: { DRDY SENSE ERR }
[ 1781.933067] ata1.00: error: { UNC }
[ 1782.054086] ata1.00: configured for UDMA/133
[ 1782.054124] sd 0:0:0:0: [sda] tag#20 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[ 1782.054133] sd 0:0:0:0: [sda] tag#20 Sense Key : Medium Error [current]
[ 1782.054140] sd 0:0:0:0: [sda] tag#20 Add. Sense: Unrecovered read error - auto reallocate failed
[ 1782.054146] sd 0:0:0:0: [sda] tag#20 CDB: Read(10) 28 00 dc 84 47 00 00 00 80 00
[ 1782.054150] blk_update_request: I/O error, dev sda, sector 3699656496 op 0x0:(READ) flags 0x80700 phys_seg 10 prio class 0
[ 1782.054199] ata1: EH complete
Okay, thank you for your help
