Why is the step attribute of the lidar action graph set to 12??
I think i answered you in the discord but again for here.
The sim step is 60 fps
The lidar will have a scan speed fo 5 Hz or it takes 0.2 seconds to do a full scan.
5 x 12 = 60
This will make sure that a full scan is published every 5 Hz rather than doing every 60th then only returning partial scans.
Thank you for bringing this to our attention. The frameSkipCount
should be set to 11 instead of 2. A documentation update will be included in the next release.
