Reset usb power
We have 3 usb cameras connected to Jetson Nano (not all streaming together).
most of the time they work ok but sometimes (not clear what causes it) they either output a corrupted static frame (usually vertical black lines over a gray background or a blurry red circle over a white background).
till now only performing a power reset to the board gets them out of this state consistently. A software reboot (sudo reboot) does not help.
what helped in some cases was doing a “usb power reset” as explained here . but it doesn’t always help.
is there a grammatically way to reset usb power which is equivalent to plugging USB device out and plugging it back in?
I don’t know of a built-in method. However, there is a post in an Ubuntu forum which might offer what you want (don’t know for sure, but it is easy to test):
https://askubuntu.com/questions/645/how-do-you-reset-a-usb-device-from-the-command-line
Incidentally, you should monitor “dmesg --follow”, and when this occurs, find out if any log was produced.
