When I sent the model in Revit to view according to the official tutorial, there was a problem. Some models could not be loaded in the view. I checked the output and said that numpy=1.19.0 was missing, but the same error still appeared after I installed it. Can anyone help me answer it, thanks :)
https://docs.omniverse.nvidia.com/con_connect/con_connect/revit.html
Loading user config located at: 'D:/InstallSoft/ov/data/Kit/View/2021.3/user.config.json'
[Info] [carb] Logging to file: C:/Users/17109/.nvidia-omniverse/logs/Kit/View/2021.3/kit_20210928_153351.log
[0.677s] [ext: omni.assets.plugins-0.0.0] startup
[0.698s] [ext: omni.kit.window.splash-0.0.0] startup
[0.755s] [ext: omni.kit.async_engine-0.0.0] startup
[0.766s] [ext: omni.kit.agent-0.1.0] startup
[0.773s] [ext: omni.kit.splash-0.2.1] startup
[0.793s] [ext: omni.usd.config-1.0.0] startup
[0.800s] [ext: omni.usd.libs-1.0.0] startup
[1.409s] [ext: omni.stats-0.0.0] startup
[1.421s] [ext: omni.gpu_foundation-0.0.0] startup
[1.478s] [ext: omni.kit.pipapi-0.0.0] startup
[1.489s] [ext: omni.usd.schema.physics-1.0.0] startup
[1.512s] [ext: omni.usd.schema.semantics-0.0.0] startup
[1.526s] [ext: omni.usd.schema.audio-0.0.0] startup
[1.541s] [ext: omni.usd.schema.anim-0.0.0] startup
[1.592s] [ext: omni.hydra.scene_delegate-0.1.0] startup
[1.634s] [ext: omni.client-0.1.0] startup
[1.680s] [ext: omni.kit.commands-0.0.0] startup
[1.702s] [ext: carb.audio-0.1.0] startup
[1.709s] [ext: omni.timeline-1.0.2] startup
[1.722s] [ext: omni.usd-1.4.5] startup
[2.135s] [ext: omni.ansel-0.2.0] startup
[2.155s] [ext: omni.hydra.iray-0.1.0] startup
[2.170s] [ext: omni.kit.pip_archive-0.0.0] startup
[2.186s] [ext: omni.kit.loop-default-0.1.0] startup
[2.187s] [ext: omni.appwindow-1.0.0] startup
[2.275s] [ext: omni.kit.test-0.0.0] startup
[2.438s] [ext: omni.kit.renderer.core-0.0.0] startup
| Driver Version: 472.12 | Graphics API: D3D12
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| 0 | NVIDIA GeForce RTX 2080 Super .. | Yes: 0 | | 8010 MB | 10de | 121db000.. |
| | | | | | 1ed3 | 0 |
| 1 | Intel(R) UHD Graphics | | | 128 MB | 8086 | 11ea0000.. |
| | | | | | 9bc4 | 0 |
| OS: Windows, Version: 10.0 (20H2), Build: 19042
| Processor: Intel(R) Core(TM) i7-10875H CPU @ 2.30GHz | Cores: 8 | Logical: 16
| Total Memory (MB): 32569 | Free Memory: 21000
| Total Page/Swap (MB): 34617 | Free Page/Swap: 20930
[4.761s] [ext: omni.ui-2.5.0] startup
[4.818s] [ext: omni.kit.mainwindow-0.0.0] startup
[4.836s] [ext: omni.kit.uiapp-0.0.0] startup
[4.837s] [ext: omni.kit.menu.utils-1.0.2] startup
[4.876s] [ext: omni.kit.material.library-1.2.0] startup
[4.972s] [ext: omni.kit.menu.create-1.0.1] startup
[4.991s] [ext: omni.kit.window.drop_support-1.0.0] startup
[5.010s] [ext: omni.kit.context_menu-1.3.2] startup
[5.072s] [ext: omni.kit.renderer.capture-0.0.0] startup
[5.102s] [ext: omni.kit.widget.versioning-1.3.4] startup
[5.128s] [ext: omni.renderer-rtx-0.0.0] startup
[5.138s] [ext: omni.hydra.rtx-0.1.0] startup
[5.191s] [ext: omni.services.facilities.base-1.0.0] startup
[5.208s] [ext: omni.kit.search_core-1.0.0] startup
[5.234s] [ext: omni.services.transport.client.base-1.0.0] startup
[5.253s] [ext: omni.services.core-1.1.1] startup
[5.523s] [ext: omni.kit.widget.filebrowser-2.2.12] startup
[5.564s] [ext: omni.services.client-0.2.0] startup
[5.627s] [ext: omni.services.transport.server.base-1.0.0] startup
[5.649s] [ext: omni.kit.widget.searchfield-1.0.4] startup
[5.678s] [ext: omni.services.transport.client.http_async-1.0.0] startup
[6.305s] [ext: omni.services.transport.server.http-1.0.0] startup
[6.512s] [ext: omni.kit.widget.path_field-2.0.3] startup
[6.541s] [ext: omni.kit.widget.zoombar-1.0.1] startup
[6.569s] [ext: omni.kit.window.popup_dialog-2.0.2] startup
[6.601s] [ext: omni.kit.notification_manager-1.0.0] startup
[6.633s] [ext: omni.kit.thumbnails.images-0.1.0] startup
[6.664s] [ext: omni.kit.widget.browser_bar-2.0.2] startup
[6.696s] [ext: omni.kit.browser.core-1.1.8] startup
[6.733s] [ext: omni.kit.window.filepicker-2.4.4] startup
[6.868s] [ext: omni.kit.window.viewport-0.0.0] startup
[8.921s] [ext: omni.anim.curve-102.1.4] startup
[8.952s] [ext: omni.kit.widget.settings-1.0.0] startup
[8.990s] [ext: omni.kit.prim.icon-0.1.0] startup
[9.027s] [ext: omni.anim.camera_tool-101.0.6] startup
[9.077s] [ext: omni.kit.browser.folder.core-1.1.5] startup
[9.117s] [ext: omni.kit.widget.prompt-1.0.0] startup
[9.154s] [ext: omni.kit.window.modifier.titlebar-1.3.16] startup
[9.182s] [ext: omni.kit.browser.sky-1.0.7] startup
[9.220s] [ext: omni.rtx.window.settings-0.6.0] startup
[9.266s] [ext: omni.kit.window.preferences-1.1.3] startup
[9.358s] [ext: omni.kit.widgets.custom-0.6.1] startup
[9.419s] [ext: omni.kit.window.sunstudy-1.0.10] startup
[9.490s] [ext: omni.rtx.settings.core-0.5.4] startup
[9.523s] [ext: omni.view.conn.manager-0.1.3] startup
[9.549s] [ext: omni.kit.window.waypoint-0.3.0] startup
[9.623s] [ext: omni.view.render_mode_modifier-0.0.0] startup
[9.626s] [ext: omni.kit.window.cursor-1.0.1] startup
[9.667s] [ext: omni.kit.tool.camera_playlist-0.1.1] startup
[9.720s] [ext: omni.graph.core-1.0.2] startup
[9.735s] [ext: omni.view.tooltip-0.1.0] startup
[9.762s] [ext: omni.view.shared-0.1.0] startup
[9.793s] [ext: omni.menubarframe-0.1.0] startup
[9.830s] [ext: omni.view.nav_tips-0.1.0] startup
[9.859s] [ext: omni.view.render-0.1.0] startup
[9.904s] [ext: omni.view.preference-0.1.0] startup
[9.941s] [ext: omni.view.dashboard-0.1.0] startup
[9.999s] [ext: omni.kit.telemetry-0.1.0] startup
[10.017s] [ext: omni.services.registry-1.0.0] startup
[Warning] [omni.telemetry.transmitter] Couldn't acquire tokens interface and initialize default tokens.
[10.252s] [ext: omni.kit.window.waypoint_manager-0.1.0] startup
[10.303s] [ext: omni.services.facilities.log-1.0.0] startup
[10.337s] [ext: omni.services.usd-1.0.0] startup
[10.372s] [ext: omni.services.facilities.workqueue-1.0.0] startup
[10.407s] [ext: omni.kit.stage_templates-1.0.6] startup
[10.457s] [ext: omni.services.facilities.config-1.0.0] startup
[10.492s] [ext: omni.videoencoding-0.1.0] startup
[10.507s] [ext: omni.kit.widget.stage-2.6.6] startup
[10.568s] [ext: omni.kit.window.file-1.3.3] startup
[10.685s] [ext: omni.kit.controlport-1.0.0] startup
[10.731s] [ext: omni.kit.capture-0.4.7] startup
[10.785s] [ext: omni.kit.window.property-1.6.2] startup
[10.841s] [ext: omni.kit.window.content_browser-2.4.5] startup
[10.950s] [ext: omni.kit.tool.collect-2.0.6] startup
[11.015s] [ext: omni.kit.hydra_texture-0.1.0] startup
[11.077s] [ext: omni.view.movie_maker-0.3.0] startup
[11.127s] [ext: omni.kit.property.usd-3.11.3] startup
[11.222s] [ext: omni.kit.thumbnails.mdl-1.0.7] startup
[11.276s] [ext: omni.kit.browser.asset-1.1.1] startup
[11.329s] [ext: omni.kit.widget.material_preview-1.0.2] startup
[11.387s] [ext: omni.kit.widget.stage_icons-1.0.2] startup
[11.445s] [ext: omni.kit.property.material-1.7.0] startup
[11.507s] [ext: omni.kit.browser.material-1.1.5] startup
[11.566s] [ext: omni.kit.widget.graph-1.1.4] startup
[11.634s] [ext: omni.view.project_manager-0.1.0] startup
2021-09-28 07:34:02 [11,375ms] [Warning] [carb.python] view project manager loaded
[11.673s] [ext: omni.kit.window.stage-2.3.4] startup
[11.736s] [ext: omni.kit.window.section-102.1.6] startup
[11.840s] [ext: omni.kit.window.material-1.0.4] startup
[11.917s] [ext: omni.kit.window.extensions-1.0.2] startup
[11.991s] [ext: omni.kit.utility.icon_modifier-0.1.2] startup
[12.053s] [ext: omni.view.toolbar-0.1.6] startup
[12.112s] [ext: omni.kit.tool.fileshare-0.1.0] startup
[12.170s] [ext: omni.kit.widget.layers-1.5.8] startup
[12.269s] [ext: omni.kit.window.script_editor-1.5.0] startup
[12.275s] [ext: omni.view.startup-0.1.0] startup
[12.339s] [ext: omni.view.mode.toggle-0.1.0] startup
[12.384s] [ext: omni.omniconfig-0.1.0] startup
[12.423s] [ext: omni.view.viewport.manager-0.1.0] startup
2021-09-28 07:34:03 [12,172ms] [Warning] [omni.kit.ui] Failed to remove menu with path: Window/Console. It doesn't exist.
2021-09-28 07:34:03 [12,173ms] [Warning] [omni.kit.ui] Failed to remove menu with path: Window/Material Preview. It doesn't exist.
2021-09-28 07:34:03 [12,176ms] [Warning] [omni.kit.ui] Failed to remove menu with path: Advanced/Update Content Tool. It doesn't exist.
2021-09-28 07:34:03 [12,182ms] [Warning] [omni.kit.ui] Failed to set value for menu with path: Window/Layer. It doesn't exist.
[12.480s] [ext: omni.kit.window.console-0.1.0] startup
[12.485s] [ext: omni.command.usd-1.0.1] startup
[12.532s] [ext: omni.view.menubar.connection-0.1.0] startup
[12.584s] [ext: omni.kit.selection-0.1.0] startup
[12.645s] [ext: omni.kit.asset_converter-1.1.36] startup
[12.766s] [ext: omni.kit.menu.file-1.0.3] startup
[12.830s] [ext: omni.kit.menu.edit-1.0.3] startup
[12.898s] [ext: omni.kit.window.title-1.1.0] startup
[12.970s] [ext: omni.kit.primitive.mesh-1.0.0] startup
[13.044s] [ext: omni.kit.tool.asset_importer-2.3.12] startup
[13.140s] [ext: omni.view.file_menu-0.1.0] startup
[13.188s] [ext: omni.iray.settings.core-0.6.2] startup
[13.238s] [ext: omni.view.compass-0.0.0] startup
[13.240s] [ext: omni.kit.window.status_bar-0.1.0] startup
[13.242s] [ext: omni.kit.importer.cad-0.2.2] startup
Looking in links: d:\installsoft\ov\pkg\view-2021.3.6\kit\extscore\omni.kit.pip_archive\pip_archive
ERROR: Could not find a version that satisfies the requirement numpy==1.19.0 (from versions: none)
ERROR: No matching distribution found for numpy==1.19.0
2021-09-28 07:34:05 [13,775ms] [Warning] [carb.python] [omni.kit.pipapi] 'numpy==1.19.0' failed to install.
2021-09-28 07:34:05 [13,775ms] [Warning] [omni.ext.plugin] [ext: omni.kit.importer.cad-0.2.2] extension.toml: [[native.plugins]] is deprecated, please rename to [[native.plugin]] (no 's' letter)
[14.422s] [ext: omni.view.aboutwindow-0.1.0] startup
[14.478s] [ext: omni.kit.tool.navigation-1.0.5] startup
[14.552s] [ext: omni.app.view-2021.3.0] startup
[14.552s] app started
2021-09-28 07:34:05 [14,471ms] [Error] [carb.python] [py stderr]: e[32mINFOe[0m: Waiting for application startup.
2021-09-28 07:34:05 [14,715ms] [Error] [carb.python] [py stderr]: e[32mINFOe[0m: Application startup complete.
2021-09-28 07:34:05 [14,718ms] [Error] [carb.python] [py stderr]: e[32mINFOe[0m: Uvicorn running on e[1mhttp://0.0.0.0:8011e[0m (Press CTRL+C to quit)
2021-09-28 07:34:06 [14,850ms] [Error] [omni.usd] Failed to open : omniverse://localhost/Users/wychao30/SendToView/RAC_basic_sample_project_210928_153342/RAC_basic_sample_project_210928_153342.project.usd
[15.157s] [ext: omni.kit.builtin.init] startup
[15.157s] [ext: omni.kit.builtin.menu] startup
2021-09-28 07:34:06 [14,861ms] [Warning] [omni.kit.ui] Failed to set value for menu with path: Window/Script Editor. It doesn't exist.
2021-09-28 07:34:06 [14,892ms] [Warning] [omni.kit.ui] Failed to set value for menu with path: Window/Content. It doesn't exist.
2021-09-28 07:34:06 [14,934ms] [Error] [carb.python] [py stderr]: d:\installsoft\ov\pkg\view-2021.3.6\kit\python\lib\asyncio\events.py:88: RuntimeWarning: coroutine 'FilePickerModel.find_item_in_subtree_async' was never awaited
self._context.run(self._callback, *self._args)
RuntimeWarning: Enable tracemalloc to get the object allocation traceback
2021-09-28 07:34:06 [14,937ms] [Warning] [carb.python] Cannot list omniverse://localhost/Users/wychao30/SendToView/RAC_basic_sample_project_210928_153342/.thumbs/, error code: Result.ERROR_NOT_FOUND.
2021-09-28 07:34:06 [14,938ms] [Warning] [carb.python] Cannot list omniverse://localhost/Users/wychao30/SendToView/RAC_basic_sample_project_210923_160952/.thumbs/, error code: Result.ERROR_NOT_FOUND.
2021-09-28 07:34:06 [14,938ms] [Warning] [carb.python] Cannot list omniverse://localhost/Users/wychao30/SendToView/RAC_basic_sample_project_210923_160655/.thumbs/, error code: Result.ERROR_NOT_FOUND.
2021-09-28 07:34:06 [14,939ms] [Warning] [carb.python] Cannot list omniverse://localhost/Users/wychao30/SendToView/RAC_basic_sample_project_210923_155748/.thumbs/, error code: Result.ERROR_NOT_FOUND.
2021-09-28 07:34:06 [14,939ms] [Warning] [carb.python] Cannot list omniverse://localhost/Users/wychao30/SendToView/RAC_basic_sample_project_210922_200258/.thumbs/, error code: Result.ERROR_NOT_FOUND.
2021-09-28 07:34:06 [14,980ms] [Warning] [carb.python] Cannot list omniverse://localhost/Users/wychao30/SendToView/RAC_basic_sample_project_210928_153342/.thumbs/, error code: Result.ERROR_NOT_FOUND.
2021-09-28 07:34:06 [14,981ms] [Warning] [carb.python] Cannot list omniverse://localhost/Users/wychao30/SendToView/RAC_basic_sample_project_210923_160952/.thumbs/, error code: Result.ERROR_NOT_FOUND.
2021-09-28 07:34:06 [14,983ms] [Warning] [carb.python] Cannot list omniverse://localhost/Users/wychao30/SendToView/RAC_basic_sample_project_210923_160655/.thumbs/, error code: Result.ERROR_NOT_FOUND.
2021-09-28 07:34:06 [14,983ms] [Warning] [carb.python] Cannot list omniverse://localhost/Users/wychao30/SendToView/RAC_basic_sample_project_210923_155748/.thumbs/, error code: Result.ERROR_NOT_FOUND.
2021-09-28 07:34:06 [14,984ms] [Warning] [carb.python] Cannot list omniverse://localhost/Users/wychao30/SendToView/RAC_basic_sample_project_210922_200258/.thumbs/, error code: Result.ERROR_NOT_FOUND.
[16.177s] [ext: omni.app.view-2021.3.0] shutdown
[16.178s] [ext: omni.kit.window.console-0.1.0] shutdown
2021-09-28 07:34:07 [16,018ms] [Warning] [carb.python] /OmniverseKit_Persp
2021-09-28 07:34:07 [16,020ms] [Warning] [carb.python] /OmniverseKit_Front
2021-09-28 07:34:07 [16,021ms] [Warning] [carb.python] /OmniverseKit_Top
2021-09-28 07:34:07 [16,023ms] [Warning] [carb.python] /OmniverseKit_Right
2021-09-28 07:34:07 [16,113ms] [Warning] [omni.kit.ui] Failed to remove menu with path: Help/飦?Python Scripting Manual. It doesn't exist.
2021-09-28 07:34:07 [16,118ms] [Warning] [omni.kit.ui] Failed to remove menu with path: Window/Waypoint Manager. It doesn't exist.
2021-09-28 07:34:08 [17,357ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : D:\installsoft\ov\pkg\view-2021.3.6\exts\omni.kit.window.sunstudy-1.0.10+cp37\data\skies\Sky_Elements\materials\SunsetSkyMat.mdl(487,19): C183 unused parameter 'NorthOrientation'
2021-09-28 07:34:08 [17,360ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : D:\installsoft\ov\pkg\view-2021.3.6\exts\omni.kit.window.sunstudy-1.0.10+cp37\data\skies\Sky_Elements\materials\SunsetSkyMat.mdl(504,19): C183 unused parameter 'SunIntensity'
2021-09-28 07:34:08 [17,369ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : D:\installsoft\ov\pkg\view-2021.3.6\exts\omni.kit.window.sunstudy-1.0.10+cp37\data\skies\Sky_Elements\materials\SunsetSkyMat.mdl(487,19): C183 unused parameter 'NorthOrientation'
2021-09-28 07:34:08 [17,370ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : D:\installsoft\ov\pkg\view-2021.3.6\exts\omni.kit.window.sunstudy-1.0.10+cp37\data\skies\Sky_Elements\materials\SunsetSkyMat.mdl(504,19): C183 unused parameter 'SunIntensity'
2021-09-28 07:34:08 [17,372ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : D:\installsoft\ov\pkg\view-2021.3.6\exts\omni.kit.window.sunstudy-1.0.10+cp37\data\skies\Sky_Elements\materials\SunsetSkyMat.mdl(487,19): C183 unused parameter 'NorthOrientation'
2021-09-28 07:34:08 [17,373ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : D:\installsoft\ov\pkg\view-2021.3.6\exts\omni.kit.window.sunstudy-1.0.10+cp37\data\skies\Sky_Elements\materials\SunsetSkyMat.mdl(504,19): C183 unused parameter 'SunIntensity'
2021-09-28 07:34:08 [17,374ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : D:\installsoft\ov\pkg\view-2021.3.6\exts\omni.kit.window.sunstudy-1.0.10+cp37\data\skies\Sky_Elements\materials\SunsetSkyMat.mdl(487,19): C183 unused parameter 'NorthOrientation'
2021-09-28 07:34:08 [17,374ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : D:\installsoft\ov\pkg\view-2021.3.6\exts\omni.kit.window.sunstudy-1.0.10+cp37\data\skies\Sky_Elements\materials\SunsetSkyMat.mdl(504,19): C183 unused parameter 'SunIntensity'
2021-09-28 07:34:08 [17,375ms] [Warning] [rtx.neuraylib.plugin] Compiler Core: D:\installsoft\ov\pkg\view-2021.3.6\exts\omni.kit.window.sunstudy-1.0.10+cp37\data\skies\Sky_Elements\materials\SunsetSkyMat.mdl(487,19): C183 unused parameter 'NorthOrientation'
2021-09-28 07:34:08 [17,375ms] [Warning] [rtx.neuraylib.plugin] Compiler Core: D:\installsoft\ov\pkg\view-2021.3.6\exts\omni.kit.window.sunstudy-1.0.10+cp37\data\skies\Sky_Elements\materials\SunsetSkyMat.mdl(504,19): C183 unused parameter 'SunIntensity'
2021-09-28 07:34:08 [17,380ms] [Warning] [rtx.neuraylib.plugin] Compiler Core: D:\installsoft\ov\pkg\view-2021.3.6\exts\omni.kit.window.sunstudy-1.0.10+cp37\data\skies\Sky_Elements\materials\SunsetSkyMat.mdl(504,19): C183 unused parameter 'SunIntensity'
2021-09-28 07:34:09 [18,377ms] [Warning] [omni.hydra.scene_delegate.plugin] Calling setBypassRenderSkelMeshProcessing for prim /Environment/DefaultSky/AxisNorth/ArrowsNWSE/Compass that is not usdskel mesh type
2021-09-28 07:34:10 [19,029ms] [Warning] [gpu.foundation.plugin] Requesting texture to use texture streaming, but the service isn't available.The texture will be created as a regular resource.
2021-09-28 07:34:11 [19,810ms] [Warning] [carb.python] Delay hide not finished correctly: {'Render Settings': True, 'Material Editor': False, 'Property': True, 'Console': True, 'Stage': True}
