Hello, I’ve recently started to use omniverse create for archviz, im experiencing some strange issues when using LiveSync, most of the time when i move objects around, change them , change materials the stage at omniverse gets all messed up: materials can jump from one object to another, some objects can even dissapear. sometimes moving the object again gets it sorted, and then again. Additionally UV mapping works only one time, when i map an object the first time it gets registered in omniverse , however if i want then to change the mapping it wont get to omniverse until i delete the mapping channel and do that again… are these known issues? Thank you
3060ti
