I am having an issue where I have a /map topic and its showing on my “rostopic list” command but it is not connected to my Isaac Sim environment. I published a PoseTree which has no parent prim so that it is set to “world” by default. I then add my robot’s links to the target prims. However, I have uploaded a map to my roslaunch file so that I can see it in rviz, but it is not connecting to my world environment. I am pretty much creating a Navigation Stack program for a custom autonomous robot. This is what it looks like for the ROS frame map (without static transforms):
I have tried another idea where I publish static transforms from the /map topic to the world and /odom but its splits the graph in two (with static transforms):
I would like to know if I am setting my PoseTree incorrectly or there is something I am not seeing that I have to set up in Isaac Sim. An example of my PoseTree is located below:
and my a_star.launch file is located below:
<?xml version="1.0" encoding="UTF-8"?>
<!-- High level launch file for Unit 3 A-Star exercise solution -->
<!-- Requires simulation w/robot running -->
<launch>
<arg name="model" default="$(find jeep_model)/urdf/jeep_updated_official.urdf"/>
<arg name="gui" default="true" />
<param name="robot_description" command="$(find xacro)/xacro --inorder $(arg model)" />
<param name="use_gui" value="$(arg gui)"/>
<!-- Run the map server to load a pre-made map -->
<arg name="map_file" default="$(find jeep_nav)/maps/UTSA_ENV_DRAFT/utsa_NE.yaml"/>
<node name="map_server" pkg="map_server" type="map_server" args="$(arg map_file)" />
<!-- MOVE_BASE -->
<include file="$(find jeep_nav)/launch/move_base.launch" />
<!-- Determine whether to run Rviz or not & set Rviz config file-->
<arg name="use_rviz" default="true" />
<arg name="rvizconfig" default="$(find jeep_nav)/rviz/jeep.rviz"/>
<!-- Launching Rviz -->
<node if="$(arg use_rviz)" name="rviz" pkg="rviz" type="rviz" respawn="false" args="-d $(arg rvizconfig)"/>
<node name="joint_state_publisher" pkg="joint_state_publisher" type="joint_state_publisher" />
<node name="robot_state_publisher" pkg="robot_state_publisher" type="state_publisher" />
<!-- Start service server that responds with a plan for global path planning -->
<node pkg="jeep_nav" name="a_star_solution" type="a_star.py" output="screen"/>
</launch>
Thank you and if you need information, please let me know.
