RTX not supported on GPU 0 - AskLinkIddDriver occupying GPU slot on Razer Blade 15
Important: Isaac Sim support
Note: For Isaac Sim support, the community is gradually transitioning from this forum to the Isaac Sim GitHub repository so that questions and issues can be tracked, searched, and resolved more efficiently in one place. Whenever possible, please create a GitHub Discussion or Issue there instead of starting a new forum topic.
Note: For any Isaac Lab topics, please submit your topic to its GitHub repo ( GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim · GitHub ) following the instructions provided on Isaac Lab’s Contributing Guidelines ( Contribution Guidelines — Isaac Lab Documentation ).
System: Razer Blade 15 2022 (RZ09-0421), Intel i7-12800H + NVIDIA RTX 3070 Ti Laptop GPU
Isaac Sim version: 5.1.0-rc.19
OS: Windows 11
Driver: 32.0.16.1047
Issue:
Isaac Sim always fails with “Raytracing is not supported on GPU: 0”.
Root cause identified: “AskLinkIddDriver Device” is occupying GPU 0 slot, pushing the RTX 3070 Ti to GPU 1. Isaac Sim always selects GPU 0 which is the virtual display driver, not the actual NVIDIA GPU.
Already tried:
  • Updated NVIDIA driver to latest
  • Set BIOS to Discrete GPU only
  • Set kit.exe to High Performance in Windows Graphics settings
  • Uninstalled AskLinkIddDriver but it comes back
  • Tried --/renderer/activeGpu=1 launch parameter (caused “Invalid backbuffer” error)
How can I force Isaac Sim to use GPU 1 (RTX 3070 Ti)?
6.0.0
5.1.0
5.0.0
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 24.04
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model:
  • Driver Version:
Topic Description
Detailed Description
(Describe the issue in detail, including what you were trying to do, what you expected to happen, and what actually happened)
Steps to Reproduce
(Add more steps as needed)
Error Messages
(If applicable, copy and paste any error messages you received)
Screenshots or Videos
(If applicable, add screenshots or links to videos that demonstrate the issue)
Additional Information
What I’ve Tried
(Describe any troubleshooting steps you’ve already taken)
Related Issues
(If you’re aware of any related issues or forum posts, please link them here)
Additional Context
(Add any other context about the problem here)
Thanks for the detailed diagnosis – identifying the AskLinkIddDriver as the root cause saves a lot of back-and-forth.
What’s Happening
The “AskLinkIddDriver Device” is a Windows Indirect Display Driver (IDD) – a virtual display adapter typically installed by remote desktop or virtual monitor software (AnyDesk, Parsec, Sunshine/Moonlight, RustDesk, etc.). It registers as a GPU in the DirectX/Vulkan device list, and on your system it landed at index 0, pushing the RTX 3070 Ti to index 1.
Isaac Sim’s renderer enumerates all GPU devices via Vulkan/DirectX, then selects the first RTX-capable one. When the IDD adapter sits at index 0, the renderer tries it first, finds no raytracing support, and reports the error you’re seeing. The --/renderer/activeGpu=1 flag should point it to the correct GPU, but the “Invalid backbuffer” error occurs because on Windows, the presentation swapchain (backbuffer) is normally created on the GPU that owns the display output, and there’s a mismatch when the window is on a different adapter.
Fix
Option 1 – Disable the IDD driver (recommended)
  1. Open Device Manager (Win+X > Device Manager)
  2. Expand Display adapters
  3. Right-click AskLinkIddDriver Device > Disable device
  4. Relaunch Isaac Sim
To prevent it from coming back, find which application installed it. Open an elevated PowerShell and run:
pnputil /enum-drivers | Select-String -Pattern "AskLink" -Context 5,5
This will show the driver package and its original source. Uninstall the parent application or its virtual display component, then remove the driver:
pnputil /delete-driver <oem##.inf> /uninstall
Option 2 – Use activeGpu in headless/streaming mode
If you need the IDD driver for remote access and run Isaac Sim headless or via streaming:
isaac-sim.bat --no-window --/renderer/activeGpu=1
The --no-window flag skips backbuffer/swapchain creation, which avoids the “Invalid backbuffer” error you hit when using --/renderer/activeGpu=1 with a window.
Option 3 – Force GPU via Windows settings
  1. Open Settings > System > Display > Graphics
  2. Add kit.exe (located in your Isaac Sim install under kit/kit.exe)
  3. Click Options > select High performance (which maps to the NVIDIA GPU)
  4. This only helps with Windows GPU preference for DX12; it may not override Vulkan device enumeration, but it’s worth trying in combination with Option 1
Verifying the Fix
After disabling the IDD driver, launch Isaac Sim and check the log file. You should see a GPU table like this in the log (under [gpu.foundation]):
| GPU | Name                          | Active | LDA | GPU Memory |
| 0   | NVIDIA GeForce RTX 3070 Ti    | Yes: 0 |     | 8192 MB    |
If the RTX 3070 Ti is listed as GPU 0 with Active: Yes, you’re good.
Note on Driver Version
Your driver shows as 32.0.16.1047 – that’s the Windows internal version format. The NVIDIA version is the last five digits: 580.88 (R580 branch). Isaac Sim 5.1.0 recommends driver R580+, so your driver should be compatible: Isaac Sim Requirements — Isaac Sim Documentation
Update:
  • Uninstalled AskLink application and deleted all three drivers (oem27, oem22, oem41)
  • Uninstalled Intel Iris Xe Graphics from Device Manager (hidden devices)
  • Device Manager now shows only NVIDIA GeForce RTX 3070 Ti
But Isaac Sim still shows deviceMask: 1 and same RTX error. It seems Vulkan still enumerates two GPUs even though only the NVIDIA GPU is visible in Device Manager.
What is the next step to verify/fix the Vulkan GPU enumeration order?
Good progress getting Device Manager cleaned up – that’s the right direction.
The remaining issue is that Vulkan has its own GPU enumeration path that doesn’t
depend on Device Manager. It reads from the Windows registry directly, so ghost
ICD (Installable Client Driver) entries from the removed AskLinkIddDriver can
persist even after the device is gone from Device Manager.
What’s Happening
Vulkan enumerates GPUs through registry keys under:
HKEY_LOCAL_MACHINE\SOFTWARE\Khronos\Vulkan\Drivers
Each entry maps to an ICD .json manifest file on disk. Even though you deleted
the oem27/oem22/oem41 .inf packages and the device no longer shows in Device
Manager, the Vulkan ICD entry may still be registered. That’s why deviceMask: 1
persists – Vulkan is still seeing a phantom adapter at index 0.
Fix – Clean Up the Vulkan ICD Registry
Step 1: Check what’s in the registry
Get-ItemProperty "HKLM:\SOFTWARE\Khronos\Vulkan\Drivers" | Format-List
Look for any .json path that references AskLink, IddDriver, IndirectDisplay,
or any path that no longer exists on disk. Also check the 32-bit hive:
Get-ItemProperty "HKLM:\SOFTWARE\WOW6432Node\Khronos\Vulkan\Drivers" | Format-List
Step 2: Verify the file actually exists
For each entry, check whether the .json file is still on disk. Example:
Test-Path "C:\Windows\System32\DriverStore\FileRepository\asklinkidddriver_*.inf_amd64_*\AskLinkIddDriverVulkan.json"
If the path doesn’t exist, the entry is a ghost.
Step 3: Remove ghost ICD entries
For any entry that no longer has a file on disk, delete the registry value. Replace
C:\path\to\ghost.json with the actual path from Step 1:
# Elevated PowerShell
Remove-ItemProperty -Path "HKLM:\SOFTWARE\Khronos\Vulkan\Drivers" -Name "C:\path\to\ghost.json"
Remove-ItemProperty -Path "HKLM:\SOFTWARE\WOW6432Node\Khronos\Vulkan\Drivers" -Name "C:\path\to\ghost.json"
Step 4: Verify with vulkaninfo
Isaac Sim ships its own vulkaninfo. Run it to confirm only one GPU is listed:
C:\isaacsim\kit\vulkaninfo.exe --summary
You should see only the NVIDIA RTX 3070 Ti in the device list, no IDD adapter.
Step 5: Relaunch Isaac Sim
After cleaning the registry, launch normally (without --/renderer/activeGpu).
Check the log for the GPU table – the RTX 3070 Ti should be GPU 0 with Active: Yes.
Alternative: Force DirectX instead of Vulkan
If the Vulkan ICD cleanup is complicated, a quick workaround is to switch Isaac Sim
to DirectX (D3D12). DirectX respects Windows GPU preference settings and is less
affected by ghost ICD entries. Edit C:\isaacsim\apps\isaacsim.exp.full.kit and
add vulkan = false under the [settings.app] section:
[settings.app]
# ...existing settings...
vulkan = false
This bypasses the Vulkan enumeration entirely. Performance is comparable on Windows
since D3D12 is the native API. Several users with similar multi-adapter enumeration
issues have had success with this workaround (see this related thread).
Hi @renault1424, we wanted to follow up on the Vulkan ICD registry cleanup steps shared above. Since we haven’t heard back, we’re closing this thread. 32.0.16.1047 represents 610.47 driver version. It’s not a production branch driver. Please use 595.97, stated in Technical Requirements — Omniverse Developer Guide. If the ghost registry entries are still causing issues or the steps didn’t resolve it, please open a new topic on the forum or the Isaac Sim GitHub and link back to this thread that way we can continue helping. Thanks for the detailed diagnosis!
