**• Hardware Platform (Jetson / GPU)**V100
• DeepStream Version 5.1.0
• TensorRT Version 7.2.2.3
I want to run two apps on the device(V100) at the same time and output the corresponding rtsp stream, but when I use VLC to open the rtsp stream output by one of the apps, the screen is mixed with the rtsp stream of the other app, and the screen is blurred.
They use different port numbers.
What should I do to read the rtsp streams of two apps separately?
Thanks very much!
