Scaling factor in Custom Board with AGX Xavier
HI,
I have a custom carrier board which is having multiple DP displays.
The supported resolution for the DP displays are different.
One display supports 1280x768 while the other display supports multiple resolution with a maximum resolution of 1920x1080.
Both the displays are up. Issue is regarding the size of the menu and title bars.
The smaller display is having the scale for menu and title bar value as 2 while the same for the bigger display is 1.
If I make the scale value in the GUI for the smaller display also 1, then the size of the icons are proper.
It would be great help if anyone could help me out to figure out how these scale values are being assigned to the Display UI so that I could edit and update the values in the UI.
any pointers to move on?
Sorry that could you take a photo so that we would be understand it easier.
Hi @WayneWWW ,
I have attached an video of the change in the display resolution in the custom board.
I think it will give a clear picture for everyone.
