Settings angular velocity in circular conveyor belt
I am using Circular conveyor belt in USD Composer. I am having some trouble setting the angular velocity for circular conveyor belt simulation.
Based on some trial and error, below is the value - -20,20,-30 I applied which kind of takes the cube to next end of the circular conveyor.
I checked the simulation demo scene of conveyor belt where angular velocity is set for z-axis only.
When I applied the same (z-axis only) on the circular conveyor belt, nothing happened.
I would like to know what are the correct ways to set angular velocity for circular conveyor belt. I checked documentation but there are not much information about the same.
It would be great if anyone could add some pointers on the same.
Thanks in advance.
Did you try the other axis, like the Y axis? Some stages are set up Z up and some Y up. You can change that preference in your “State” settings in “Preferences”.
