Simulation Slowdown with PointCloud2 Subscriber
Hello everyone,
I’m currently working on a project using NVIDIA Isaac Sim to synchronize a simulated robot with data from a ROS2 bagfile recorded from a real robot. The synchronization of the robot’s movements works perfectly; however, I encounter significant slowdowns in the simulation as soon as a PointCloud2 subscriber starts receiving messages.
Here’s the code snippet I’m using:
import argparse
from utils.file_operations import read_yaml
from utils.transforms import update_object_dict_with_transforms, process_transform, check_pose_deviation
#                       Read the YAML configuration file                       #
parser = argparse.ArgumentParser()
parser.add_argument("--config_file", help="Path to the configuration file", default="config/params.yaml")
args = parser.parse_args()
config = read_yaml(args.config_file)
#                            Start The SimulationApp                           #
import isaacsim
from omni.isaac.kit import SimulationApp
simulation_app = SimulationApp(launch_config=config.launch_config)
import numpy as np
import warnings
import threading
import omni.client
import omni.kit.commands
import omni.kit.app
import omni.timeline
import omni.usd
from omni.isaac.core import World
from omni.isaac.core.utils.extensions import enable_extension
from omni.isaac.core.utils.stage import add_reference_to_stage
from omni.isaac.core.prims import XFormPrim
from pxr import UsdPhysics, PhysxSchema
# enable ROS2 bridge extension
enable_extension("omni.isaac.ros2_bridge")
simulation_app.update()
import rclpy
from rclpy.node import Node
from sensor_msgs.msg import PointCloud2
from sensor_msgs_py import point_cloud2
warnings.filterwarnings("ignore")
class IsaacSim(Node):
    def __init__(self):
        super().__init__('IsaacSim')
        # setting up the world
        self.world_setup()
        # load environment and robot
        self.load_env()
        self.load_robot()
        # reset ros world
        self.ros_world.reset()
    def world_setup(self):
        self.timeline = omni.timeline.get_timeline_interface()
        self.ros_world = World(stage_units_in_meters=1.0)
        self.add_physics_scene()
    def add_physics_scene(self):
        self.stage = omni.usd.get_context().get_stage()
        self.physics_scene = UsdPhysics.Scene.Define(self.stage, "/physicsScene")
        physx_scene = PhysxSchema.PhysxSceneAPI.Apply(self.stage.GetPrimAtPath("/physicsScene"))
        physx_scene.GetEnableCCDAttr().Set(False)
        physx_scene.GetEnableGPUDynamicsAttr().Set(False)
        physx_scene.GetCollisionSystemAttr().Set("PCM")
        physx_scene.GetSolverTypeAttr().Set("TGS")
        physx_scene.GetBroadphaseTypeAttr().Set("MBP")
        physx_scene.GetTimeStepsPerSecondAttr().Set(480)
    def load_env(self):
        env_url = "/root/ws/environments/" + config.environment_config.environment_usd
        add_reference_to_stage(usd_path=env_url, prim_path="/Environment")
        self.ros_world.scene.add(XFormPrim(prim_path="/Environment", name="Environment"))
    def load_robot(self):
        robot_url = "/root/ws/robots/USD/" + config.robot_config.robot_usd
        add_reference_to_stage(usd_path=robot_url, prim_path="/kairosAB")
        self.ros_world.scene.add(XFormPrim(prim_path="/kairosAB", name="kairosAB"))
    def run_simulation(self):
        self.timeline.play()
        while simulation_app.is_running():
            self.ros_world.step(render=True)
            if self.ros_world.is_playing():
                pass
        # cleanup
        self.timeline.stop()
        self.destroy_node()
        simulation_app.close()
class PointCloudSubscriber(Node):
    def __init__(self,):
        super().__init__('point_cloud_sub')
        self.subscription_point_cloud = self.create_subscription(PointCloud2, "/kairosAB/ouster/points", self.point_cloud_callback, 100)
    def point_cloud_callback(self, msg):
        print("Received")
        points_msg = np.array(list(point_cloud2.read_points(msg, field_names=("x", "y", "z"), skip_nans=True)))
        print("Finished processing")
        print("_________________")
def main():
    rclpy.init()
    node1 = IsaacSim()
    node2 = PointCloudSubscriber()
    executor = rclpy.executors.MultiThreadedExecutor()
    executor.add_node(node1)
    executor.add_node(node2)
    # Spin in a separate thread
    executor_thread = threading.Thread(target=executor.spin, daemon=True)
    executor_thread.start()
    node1.run_simulation()
    rclpy.shutdown()
    executor_thread.join()
if __name__ == '__main__':
    main()
I’ve tried implementing multi-threading to address the issue, but unfortunately, the problem persists. Below is a video demonstrating how the simulation slows down once the first PointCloud2 message is received and processed:
I would like the PointCloud2 subscriber to operate independently from the simulation to prevent any slowdowns. Does anyone have any suggestions or solutions on how I can achieve this?
Any help would be greatly appreciated!
Thank you,
Lukas
I can confirm this also happens in my setup.
Machine A: Isaac Sim 5.1
Windows 11
env variables set : FASTRTPS_DEFAULT_PROFILES_FILE, RMW_IMPLEMENTATION, ROS_DOMAIN_ID, ROS_IP, ROS_HOSTNAME
These are set accordingly.
Also acts as a Hotspot, Self IP: 192.168.137.1
Machine B:
Ubuntu 2204, ROS2 Humble,
environement variables set accodingly.
ROS_IP=192.168.137.xxx
when Machine B subscribes to ros topic pointcloud2 messages (RTX Lidar / PhysX Lidar) :
Network usage is around 980mbps
Isaac sim slows down.
I tried the other way around, isaac sim running in machine B, and Machine A with wsl2 ros2
still the same. Very high network usage and isaac slows down
I came across this while reviewing open tickets. Since the last response was about 6 months ago, this ticket might be out-dated, so I’m closing it. Please open a new bug if you still need support. Thanks!
