Hi William,
Thanks for response.
As for (3), I use a python script which will subscribe the topic and check with real time and sim time.
The output is like below
(a) one camera
[INFO] [1761543710.325930128] [topic_rate_monitor]: [/visual_slam/tracking/vo_pose] avg_freq = 58.00 Hz (sim_time = 6.000s)
[INFO] [1761543714.416051852] [topic_rate_monitor]: [/visual_slam/tracking/vo_pose] avg_freq = 55.00 Hz (sim_time = 7.000s)
[INFO] [1761543718.497856991] [topic_rate_monitor]: [/visual_slam/tracking/vo_pose] avg_freq = 52.00 Hz (sim_time = 8.000s)
[INFO] [1761543722.602302578] [topic_rate_monitor]: [/visual_slam/tracking/vo_pose] avg_freq = 55.00 Hz (sim_time = 9.000s)
[INFO] [1761543726.699055059] [topic_rate_monitor]: [/visual_slam/tracking/vo_pose] avg_freq = 52.00 Hz (sim_time = 10.000s)
(b) two camera
[INFO] [1761543590.213153069] [topic_rate_monitor]: [/visual_slam/tracking/vo_pose] avg_freq = 36.61 Hz (sim_time = 6.000s)
[INFO] [1761543594.455075965] [topic_rate_monitor]: [/visual_slam/tracking/vo_pose] avg_freq = 39.68 Hz (sim_time = 7.000s)
[INFO] [1761543598.541919409] [topic_rate_monitor]: [/visual_slam/tracking/vo_pose] avg_freq = 36.00 Hz (sim_time = 8.000s)
[INFO] [1761543602.635702693] [topic_rate_monitor]: [/visual_slam/tracking/vo_pose] avg_freq = 37.24 Hz (sim_time = 9.000s)
[INFO] [1761543606.783887778] [topic_rate_monitor]: [/visual_slam/tracking/vo_pose] avg_freq = 36.77 Hz (sim_time = 10.000s)
The rate is calculated based on sim time.
From the log, 1 second in sim time will be around 4 second in real time.
Is the rate of vo_pose like above between 1 and 2 camera expected (from 5xHz to 3xHz after use 2 cameras for vslam)?
BTW, to control the output rate of camera, just change frameSkipCount is enough, right?
In the tutorial, it seems mentioned ActionGraph, but I don’t see anywhere use it in our testing environment. Do I need to setup some ActionGraph?
As for (2), it can output as expect now.
But when I try to run 2 camera with this 1920x1200 resolution. It seems will affect the frame rate of image topic and cause vslam can’t work well
Here is the example of output frame rate
INFO] [1761545767.781951532] [topic_rate_monitor]: [/front_stereo_camera/left/image_rect_color] avg_freq = 50.16 Hz (sim_time = 236.000s)
[INFO] [1761545771.362406785] [topic_rate_monitor]: [/front_stereo_camera/left/image_rect_color] avg_freq = 55.00 Hz (sim_time = 237.000s)
[INFO] [1761545774.908675041] [topic_rate_monitor]: [/front_stereo_camera/left/image_rect_color] avg_freq = 52.00 Hz (sim_time = 238.000s)
[INFO] [1761545778.506122927] [topic_rate_monitor]: [/front_stereo_camera/left/image_rect_color] avg_freq = 53.00 Hz (sim_time = 239.000s)
[INFO] [1761545782.413864391] [topic_rate_monitor]: [/front_stereo_camera/left/image_rect_color] avg_freq = 24.00 Hz (sim_time = 240.000s)
[INFO] [1761545786.352308045] [topic_rate_monitor]: [/front_stereo_camera/left/image_rect_color] avg_freq = 14.48 Hz (sim_time = 241.000s)
[INFO] [1761545790.315919190] [topic_rate_monitor]: [/front_stereo_camera/left/image_rect_color] avg_freq = 23.23 Hz (sim_time = 242.000s)
[INFO] [1761545794.360182318] [topic_rate_monitor]: [/front_stereo_camera/left/image_rect_color] avg_freq = 14.48 Hz (sim_time = 243.000s)
[INFO] [1761545798.337237468] [topic_rate_monitor]: [/front_stereo_camera/left/image_rect_color] avg_freq = 16.84 Hz (sim_time = 244.000s)
[INFO] [1761545802.294282740] [topic_rate_monitor]: [/front_stereo_camera/left/image_rect_color] avg_freq = 13.85 Hz (sim_time = 245.000s)
Before I start vslam node, the output frame rate will around 5x Hz. After start vslam node, it drop to 1x ~ 2x Hz. Is this caused by computing resource or something else?
Thanks for help.
