Starting with . /runheadless.native.sh startup error-----help
2025-01-10 10:25:59 [3,864ms] [Error] [carb.glinterop.plugin] OpenGL Interop is not available. Upgrade your driver to latest for this feature.
2025-01-10 10:25:59 [3,879ms] [Error] [gpu.foundation.plugin] Multiple Installable Client Drivers (ICDs) are found for the same GPU on the system. This causes the same GPU to be reported multiple times by more than one driver and leads to instability or crash.
For NVIDIA drivers, please follow troubleshooting docs to uninstall and completely purge Linux-distribution-provided driver packages, and then reinstall your driver cleanly via .run package. Otherwise, updating Ubuntu software may reinstall a secondary ICD or override the existing NVIDIA driver.
To verify the proper NVIDIA driver installation, only one of the following icd.d folders should contain nvidia_icd.json file:
/etc/vulkan/icd.d: Location of ICDs installed from non-Linux-distribution-provided packages
/usr/share/vulkan/icd.d : Location of ICDs installed from Linux-distribution-provided packages
and this
2025-01-10 10:38:28 [14,284ms] [Warning] [omni.graph.core.plugin] OmniGraphSettings::getCudaDeviceOrdinal: unable to get a valid CUDA device id from the renderer. Defaulting to GPU0.
2025-01-10 10:38:28 [14,285ms] [Warning] [omni.graph.core.plugin] OmniGraphSettings::getCudaDeviceOrdinal: unable to get a valid CUDA device id from the renderer. Defaulting to GPU0.
Are you still facing this issue? Please use the Isaac Sim Compatibility Checker to verify that your system meets the required specifications.
Hello!
Best regards,
