I recently updated my graphics card from a Quadro FX3800 to an M4000. Everything works with the new card except the stereo 3D vision. X windows will not start if I have
option stereo “10”
set in my xorg.conf file which is the option needed for the old card to use the 3D vision emitter. The computer boots and runs fine when this option is a “3” but the emitter doesn’t work.
I am running Centos 6.8. I’ve installed the newest linux driver (367.44) and don’t get any errors when I install the driver. When I start xwindows I do see complaints about missing nvidia.ko. Have I missed a step in the installation?
I have a Acer GD235Hz monitor with 1920x1080 resolution with 120 Hz refresh rate. Digging through the x windows log file if I found the following error when
Mode is rejected: PixelClock (286.7 MHz) too high for Display Device (Max: 165.0 MHz). Mode “1920x1080_120” is invalid
I am at the end of my expertise here. Any help would be greatly appreciated. I’ve pasted my xorg.conf file below and would be happy to provide any other information.
nvidia-xconfig: X configuration file generated by nvidia-xconfig
nvidia-xconfig: version 367.44 (buildmeister@swio-display-x86-rhel47-01) Wed Aug 17 22:54:35 PDT 2016
Section “ServerLayout”
Identifier “Layout0”
Screen 0 “Screen0”
InputDevice “Keyboard0” “CoreKeyboard”
InputDevice “Mouse0” “CorePointer”
EndSection
Section “Files”
FontPath “/usr/share/fonts/default/Type1”
EndSection
Section “InputDevice”
# generated from default
Identifier “Mouse0”
Driver “mouse”
Option “Protocol” “auto”
Option “Device” “/dev/input/mice”
Option “Emulate3Buttons” “no”
Option “ZAxisMapping” “4 5”
EndSection
# generated from data in “/etc/sysconfig/keyboard”
Identifier “Keyboard0”
Driver “kbd”
Option “XkbLayout” “us”
Option “XkbModel” “pc105”
EndSection
Section “Monitor”
Identifier “Monitor0”
VendorName “Acer”
ModelName “Acer GD235HZ”
HorizSync 30.0 - 140.0
VertRefresh 56.0 - 120.0
Option “DPMS”
EndSection
Section “Device”
Identifier “Device0”
Driver “nvidia”
VendorName “NVIDIA Corporation”
Option “ModeValidation” “NoMaxPClkCheck”
EndSection
Section “Screen”
Identifier “Screen0”
Device “Device0”
Monitor “Monitor0”
DefaultDepth 24
Option “Stereo” “3”
Option “TwinView” “0”
Option “ModeDebug” “on”
SubSection “Display”
Depth 24
EndSubSection
EndSection
Section “Extensions”
Option “Composite” “Disable”
EndSection
