Synchronization of cameras and lidar with a frame trigger
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
Hello Nvidia,
I have GMSL2 cameras and a lidar Velodyne Ultra Puck, compatible and connected to my DRIVE Orin. But I would like to trigger each frame of all the sensors precisely at the same time, in order to get all the images and point clouds captured at the same time.
I know that we can internally generate a fsync signal to trigger all the cameras. But how can I send this trigger to ethernet sensors like my Velodyne ? Is it possible to send this fsync or should I use another method ?
Thank you very much for your help
Dear @nicolas.p,
AFIAK, Triggering camera/lidar at same time is not possible. Also, Velodyne does not seems to support PTP sync. I will check internally and update you on this issue.
Thank you for your answer.
And do you know if triggering camera/lidar at the same time will be available in a future release (assuming I’m using a lidar compatible with PTP) ?
No. AFAIK, we don’t support it.
