Unfortunately I do not have any spaces in the path to my vcxproj files. The only related thing I can think of that might be relevant is that I don’t have my vcxproj and sln files all relative to each other like they are defaulted to when you use the project wizard. Mine is something like
Can you send me the logs from the %AppData%\NVIDIA Corporation\Nsight Tegra\Logs? I’ll need the most recent one, or, even better, close VS, delete the logs, open it again and do one session of attaching to capture the issue in the logs.
I have the same error. If I’m just debugging my app - all ok. But there are no symbols loaded for external dependies. If I’m adding path to external libs to “Additional Library Symbols Directories” then I see that info was successfully loaded but error “Failed to attach: Object reference not set to an instance of an object.” appears. I can send the most recent log file.
upd:
These external libraries are built with “-Wl,–soname=”.
I’ll send you my email in a PM. The log file is very welcome, thank you.
Update: Bert’s issue is device-specific and is related to GDB. Unfortunately, at the moment we cannot guarantee that Nsight Tegra will work correctly on devices with API level 16 (Android 4.1). Older Nsight Tegra versions seem to work (they were bundled with an older GDB).
To anyone having the similar issues: while we’re working on a solution, please try unchecking the Android Exceptions → C++ Exception in the Exceptions window or clicking the Reset All button there. The GDB we’re currently using fails to enable handling thrown exception on some devices.
I’m having the same issue. I mainly develop on a Shield Tablet, and have not had an issue with that, but have now tried it on a S3 and I get the above error.
Resetting the exceptions didn’t fix the issue for me.
David.
Edit: I have tried it on a couple of devices on API 17 and I am not having the issue, so it seems that it is the API 16 issue you mentioned above.
We’ve fixed some of the issues that manifested in such error messages in the upcoming release. For example, it currently fails to attach if the project is built with ndk-build or another non-Nsight Tegra build system, and the primary architecture in the APK is ARMv5TE (armeabi). Building for ARMv7A (armeabi-v7a) will work around this issue.
