Error When attaching to Process to Debug: set Location to Android NDK
When trying to attach to the application process through visual studios I get the error Failed to attach: Please set the location to the Android NDK in the preferences. The preference point to the correct path for my NDK with no spaces. I saw in previous versions there were problems with there being two back slashes, but that is not the issue. Is there anything else I can try?
Hi, we are aware of this issue and will fix it in the future. Meanwhile please ensure that your startup project is the Nsight Tegra project and if the issue still reproduces then try setting the Android Directories → Android NDK Location project property to match the one in the options.
