How to access the SSD on your Jetson Orin Nano from a host machine as a flash drive ? while power on or off ?
In Ubuntu 24.10 (on my remote machine), I use sftp to access the Jetson. Of course, permissions have to be enabled for the desired folders (if not already enabled). May not be very security conscious but works for my small LAN farm.
Regards.
No. No. I need to recognize it as USB drive, For example one folder i need to be share as USB drive, When i plub to any computer it need to be recognize as USB and need to display files inside that folder.
Sorry, I may be missing the point. If you enable sftp access you can view the Jetson as a networked device with access to all shared folders using any file explorer applet.
Of course, with a physical USB drive, you do not have to worry about permissions.
Regards.
No , i need to access this specific folder as USB DRIVE when Jetson plug to any computer. Jetson orin nano power off.
My meaning is Jetson nano SSD use as USB gadget mode
This is not supported. If Orin Nano is off, all interfaces(USB, PCIe, …) are off
