Turn on Jetson AGX Xavier carrier card independently
I have many Jetson AGX Xavier DVKs that I use for development purposes. From the total quantity of 10, Three got damage and these are out of warranty. So I checked and discovered that 1.8V is directly shorted to ground, indicating that something has gone wrong with some of the components.
So, could you please let me know how I can turn on the Jetson AGX Xavier carrier card independently?
Hi, if you have good hw knowledge, you can try to locate issue based on Xavier carrier board P2822 schematic in DLC. That means you can check the 1.8V related components to find out which is damaged and then try removing it to see if issue still.
Sure,Thanks
