TX2 can not start up when the shell temperature exceeds 80°C
hello,Can I have the means to adjust TX2 so that it can start up at ambient temperature of 80 °C ?
Hi, don’t suggest that. If you can keep module in temperature less than 80c with good thermal solution, then that will be workable.
@Trumany。We are doing high temperature test of the whole machine. We want to verify the effect of start-up. Do you have any way to modify it?
No such info can be shared as it might damage chip. There are related info in thermal design guide and other thermal topics in forum, you can get more from them.
@Trumany,thank you a lot
