Experts,
from parker TRM, I understand the NVCSI supports both CPHY & DPHY. I have a requirement to interface the camera thet supports only DPHY option.
Please can you seugget where I need to look into to switch between CPhy & DPhy?
Experts,
Hi NVDIA exeprts,
With experiments, I understood default is D-PHY.
Still I am unsure how to switch to C-Phy.
hello ravikiran.hv,
here’s configuration in the kernel driver to set the NvCSI phy modes.
please refer to below,
sources/kernel/kernel-4.4/drivers/media/platform/tegra/camera/csi/csi4_registers.h
#define CFG_PHY_MODE
Next release should have c-phy implement sample code. Should be defined in the DT.
