We design own PCB,but can not startup without U29(TCA9539RTWR).
When we revamped the PCB and put U29 on, worked but HDMI can not out-put.
And if we do 1.8v to 3.3v change also will affect HDMI
Serial port printing
[0000.294] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-c4328dc3)
[0000.302] I> Default Heap @ [0xd486400 - 0xd488400]
[0000.307] I> DMA Heap @ [0x85200000 - 0x86200000]
[0000.312] I> bit @ 0xd480000
[0000.315] I> BR-BCT relocated to 0xd7020000
[0000.319] I> Boot-device: eMMC
[0000.322] I> sdmmc bdev is already initialized
[0000.327] I> pmic: reset reason (nverc)	: 0x40
[0000.331] I> Reading GPT from 512 for device 00000003
[0000.337] I> Reading GPT from 8388096 for device 00000003
[0000.345] I> Found 13 partitions in 00000003 device
[0000.349] I> Reading GPT from 512 for device 00010003
[0000.356] I> Found 29 partitions in 00010003 device
[0000.361] W> No valid slot number is found in scratch register
[0000.367] W> Return default slot: _a
[0000.370] I> A/B: bin_type (16) slot 0
[0000.374] I> Loading partition bpmp-fw at 0xd7800000
[0000.379] I> Reading two headers - addr:0xd7800000 blocks:1
[0000.384] I> Addr: 0xd7800000, start-block: 58761217, num_blocks: 1
[0000.399] I> Binary(16) of size 529040 is loaded @ 0xd7800000
[0000.405] W> No valid slot number is found in scratch register
[0000.411] W> Return default slot: _a
[0000.414] I> A/B: bin_type (17) slot 0
[0000.418] I> Loading partition bpmp-fw-dtb at 0xd79f0000
[0000.423] I> Reading two headers - addr:0xd79f0000 blocks:1
[0000.428] I> Addr: 0xd79f0000, start-block: 58763633, num_blocks: 1
[0000.442] I> Binary(17) of size 465760 is loaded @ 0xd798e200
[0000.621] I> BPMP-FW load address = 0xd7800000
0000.625] I> BPMP-FW DTB load address = 0x5018e200
[0000.630] I> Loading SCE-FW …
[0000.633] W> No valid slot number is found in scratch register
[0000.639] W> Return default slot: _a
[0000.642] I> A/B: bin_type (12) slot 0
[0000.646] I> Loading partition sce-fw at 0xd7300000
[0000.651] I> Reading two headers - addr:0xd7300000 blocks:1
[0000.656] I> Addr: 0xd7300000, start-block: 58765633, num_blocks: 1
[0000.665] I> Binary(12) of size 76592 is loaded @ 0xd7300000
[0000.670] I> Init SCE
[0000.673] I> Copy BTCM section
[0000.676] W> No valid slot number is found in scratch register
[0000.681] W> Return default slot: _a
[0000.685] I> A/B: bin_type (13) slot 0
[0000.688] I> Loading partition cpu-bootloader at 0x96000000
[0000.694] I> Reading two headers - addr:0x96000000 blocks:1
[0000.699] I> Addr: 0x96000000, start-block: 58740737, num_blocks: 1
[0000.711] I> Binary(13) of size 282736 is loaded @ 0x96000000
[0000.716] W> No valid slot number is found in scratch register
[0000.722] W> Return default slot: _a
[0000.726] I> A/B: bin_type (20) slot 0
[0000.729] I> Loading partition bootloader-dtb at 0x8520f400
[0000.735] I> Reading two headers - addr:0x8520f400 blocks:1
[0000.740] I> Addr: 0x8520f400, start-block: 58742785, num_blocks: 1
[0000.751] I> Binary(20) of size 217536 is loaded @ 0x8520f400
[0000.756] I> MB2-params(VA) @ 0xd7000000
[0000.760] I> CPUBL-params(VA) @ 0xd7000000
[0000.764] I> CPUBL-params¶ @ 0x277000000
[0000.768] I> CPU-BL loaded @ PA 0x96000000
[0000.772] I> Loading TOS …
[0000.775] W> No valid slot number is found in scratch register
[0000.781] W> Return default slot: _a
[0000.784] I> A/B: bin_type (14) slot 0
[0000.788] I> Loading partition secure-os at 0x8530f600
[0000.793] I> Reading two headers - addr:0x8530f600 blocks:1
[0000.798] I> Addr: 0x8530f600, start-block: 58744833, num_blocks: 1
[0000.807] I> Binary(14) of size 62576 is loaded @ 0x8530f600
[0000.812] I> Copying Monitor (length: 0xf270) from 0x8530f800 to 0x40000000
[0000.819] I> Erasing Monitor @ 0x8530f800
[0000.824] I> Unhalting SCE
[0000.826] I> Primary Memory Start:80000000 Size:70000000
[0000.832] I> Extended Memory Start:f0110000 Size:185ef0000
[0000.838] I> Waypoint2-ACK: 0x52012714
[0000.842] I> MB2(TBoot-BPMP) done
NOTICE:  BL31: v1.2(release):e1e4477
NOTICE:  BL31: Built : 00:08:30, May 17 2018
NOTICE:  Trusty image missing.
ERROR:   Error initializing runtime service trusty_fast
[0001.083] I> Welcome to Cboot
[0001.086] I> Cboot Version: 00.00.2014.50-t186-0c600f85
[0001.091] I> CPU-BL Params @ 0x277000000
[0001.094] I>  0) Base:0x00000000 Size:0x00000000
[0001.099] I>  1) Base:0x277f00000 Size:0x00100000
[0001.103] I>  2) Base:0x277e00000 Size:0x00100000
[0001.108] I>  3) Base:0x277d00000 Size:0x00100000
[0001.112] I>  4) Base:0x277c00000 Size:0x00100000
[0001.117] I>  5) Base:0x277b00000 Size:0x00100000
[0001.121] I>  6) Base:0x277800000 Size:0x00200000
[0001.126] I>  7) Base:0x277400000 Size:0x00400000
[0001.130] I>  8) Base:0x277a00000 Size:0x00100000
[0001.135] I>  9) Base:0x277300000 Size:0x00100000
[0001.139] I> 10) Base:0x276800000 Size:0x00800000
[0001.144] I> 11) Base:0x30000000 Size:0x00040000
[0001.148] I> 12) Base:0xf0000000 Size:0x00100000
[0001.153] I> 13) Base:0x30040000 Size:0x00001000
[0001.157] I> 14) Base:0x30048000 Size:0x00001000
[0001.162] I> 15) Base:0x30049000 Size:0x00001000
[0001.166] I> 16) Base:0x3004a000 Size:0x00001000
[0001.171] I> 17) Base:0x3004b000 Size:0x00001000
[0001.175] I> 18) Base:0x3004c000 Size:0x00001000
[0001.179] I> 19) Base:0x3004d000 Size:0x00001000
[0001.184] I> 20) Base:0x3004e000 Size:0x00001000
[0001.188] I> 21) Base:0x3004f000 Size:0x00001000
[0001.193] I> 22) Base:0x00000000 Size:0x00000000
[0001.197] I> 23) Base:0xf0100000 Size:0x00010000
[0001.202] I> 24) Base:0x00000000 Size:0x00000000
[0001.206] I> 25) Base:0x00000000 Size:0x00000000
[0001.210] I> 26) Base:0x00000000 Size:0x00000000
[0001.215] I> 27) Base:0x00000000 Size:0x00000000
[0001.219] I> 28) Base:0x84400000 Size:0x00400000
[0001.224] I> 29) Base:0x30000000 Size:0x00010000
[0001.228] I> 30) Base:0x278000000 Size:0x08000000
[0001.233] I> 31) Base:0x00000000 Size:0x00000000
[0001.237] I> 32) Base:0x276000000 Size:0x00600000
[0001.242] I> 33) Base:0x80000000 Size:0x70000000
[0001.246] I> 34) Base:0xf0110000 Size:0x185ef0000
[0001.251] I> 35) Base:0x00000000 Size:0x00000000
[0001.255] I> 36) Base:0x00000000 Size:0x00000000
[0001.260] I> 37) Base:0x2772e0000 Size:0x00020000
[0001.264] I> 38) Base:0x84000000 Size:0x00400000
[0001.268] I> 39) Base:0x96000000 Size:0x02400000
[0001.273] I> 40) Base:0x85000000 Size:0x01200000
[0001.277] I> 41) Base:0x277000000 Size:0x00280000
[0001.282] I> 42) Base:0x00000000 Size:0x00000000
[0001.286] I> 43) Base:0x00000000 Size:0x00000000
[0001.291] GIC-SPI Target CPU: 4
[0001.294] Interrupts Init done
[0001.297] calling constructors
[0001.301] initializing heap
[0001.303] initializing threads
[0001.306] initializing timers
[0001.310] creating bootstrap completion thread
[0001.314] top of bootstrap2()
[0001.318] CPU: ARM Cortex A57
[0001.321] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.326] initializing platform
[0001.329] I> Boot-device: eMMC
[0001.333] I> sdmmc bdev is already initialized
[0001.338] I> Reading GPT from 512 for device 00000003
[0001.343] I> Reading GPT from 8388096 for device 00000003
[0001.350] I> Found 13 partitions in 00000003 device
[0001.355] I> Reading GPT from 512 for device 00010003
[0001.361] I> Found 29 partitions in 00010003 device
[0001.366] W> opt-in fuse is not set, skip fuse_burning
[0001.370] I> Bl_dtb @0x8520f400
[0001.373] I> gpio framework initialized
[0001.377] I> tegrabl_gpio_driver_register: register ‘tegra_gpio_main_driver’ driver
[0001.385] I> tegrabl_gpio_driver_register: register ‘tegra_gpio_aon_driver’ driver
[0001.392] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.401] E> i2c dev write failed
[0001.404] E> tca9539_device_init: failed to write polar reg
[0001.410] E> tegrabl_tca9539_init: failed to init device!
[0001.415] E> GPIO TCA9539 driver init failed
[0001.537] I> decompressor handler not found
[0001.544] I> fixed regulator driver initialized
[0001.575] I> register ‘maxim’ power off handle
[0001.580] I> virtual i2c enabled
[0001.583] I> registered ‘maxim,max77620’ pmic
[0001.588] I> tegrabl_gpio_driver_register: register ‘max77620-gpio’ driver
[0001.597] I> Find /i2c@c250000’s alias i2c7
[0001.601] I> Reading eeprom i2c=7 address=0x50
[0001.632] I> Device at /i2c@c250000:0x50
[0001.636] I> Reading eeprom i2c=7 address=0x57
[0001.641] E> i2c dev read failed
[0001.645] E> eeprom: Failed to read I2C slave device
[0001.649] I> Eeprom read failed 0x1a89800d
[0001.654] I> Find /i2c@c240000’s alias i2c1
[0001.658] I> Reading eeprom i2c=1 address=0x51
[0001.665] E> i2c dev read failed
[0001.668] E> eeprom: Retry to read I2C slave device.
[0001.674] E> i2c dev read failed
[0001.677] E> eeprom: Failed to read I2C slave device
[0001.682] I> Eeprom read failed 0x1a89800d
[0001.686] I> Find /i2c@3160000’s alias i2c0
[0001.690] I> Reading eeprom i2c=0 address=0x50
[0001.695] E> i2c dev read failed
[0001.699] E> eeprom: Failed to read I2C slave device
[0001.703] I> Eeprom read failed 0x1a89800d
[0001.708] I> Find /i2c@3180000’s alias i2c2
[0001.712] I> Reading eeprom i2c=2 address=0x54
[0001.716] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.721] C> GPIO driver for chip_id 0x2 could not be found
[0001.726] E> cam_eeprom_read: Can’t get gpio driver
[0001.731] I> Eeprom read failed 0x2693400d
[0001.735] I> create_pm_ids: id: 3310-1000-B02-C, len: 15
[0001.740] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.754] I> found one nvdisp nodes at offset = 76304
[0001.759] I> found one nvdisp nodes at offset = 77220
[0001.768] I> enabling ‘vdd-hdmi’ regulator
[0001.772] C> GPIO driver for chip_id 0x3 could not be found
[0001.777] I> found one nvdisp nodes at offset = 78024
[0001.782] I> no valid display unit config found in dtb
[0001.787] W> display init failed
[0001.790] initializing target
[0001.793] calling apps_init()
[0001.796] starting app android_boot_app
[0001.801] I> Gpio keyboard init success
[0001.804] I> Kernel type = Normal
[0001.807] I> Loading kernel/boot.img from storage …
[0001.812] W> No valid slot number is found in scratch register
[0001.818] W> Return default slot: _a
[0001.821] I> A/B: bin_type (0) slot 0
[0001.825] I> Loading partition kernel at 0xa8000000
[0002.617] I> tegrabl_auth_payload: partition kernel (bin_type 0)
[0002.624] W> No valid slot number is found in scratch register
[0002.630] W> Return default slot: _a
[0002.633] I> A/B: bin_type (1) slot 0
[0002.636] I> Loading partition kernel-dtb at 0x92000000
[0002.649] I> tegrabl_auth_payload: partition kernel-dtb (bin_type 1)
[0002.655] I> Kernel DTB @ 0x92000000
[0002.659] I> Checking boot.img header magic … [0002.663] I> [OK]
[0002.665] I> Valid boot.img @ 0xa8000000
[0002.669] I> decompressor handler not found
[0002.673] I> Copying kernel image (488466 bytes) from 0xa8000800 to 0x80080000 … [0002.680] I> Done
[0002.682] I> Move ramdisk (len: 0) from 0xa8078000 to 0x9d000000
[0002.689] I> Updated bpmp info to DTB
[0002.694] I> Ramdisk: Base: 0x9d000000; Size: 0x0
[0002.698] I> Updated initrd info to DTB
[0002.702] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0002.709] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0002.716] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0002.724] I> disabled_core_mask: 0xffffff0c
[0002.728] W> No valid slot number is found in scratch register
[0002.733] W> Return default slot: _a
[0002.737] I> Active slot suffix:
[0002.740] I> add_boot_slot_suffix: slot_suffix =
[0002.744] I> add_serialno: Serial Num = 0421818031001
[0002.749] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2.1 androidboot.serialno=0421818031001 bl_prof_dataptr=0x10000@0x277040000 sdhci_tegra.en_boot_part_access=1
[0002.788] I> Updated bootarg info to DTB
[0002.792] E> “plugin-manager” doesn’t exist, creating
[0002.797] E> “odm-data” doesn’t exist, creating
[0002.802] I> eeprom_get_mac_addr: MAC (type: 0): 00:04:4b:a5:8a:35
[0002.809] I> eeprom_get_mac_addr: MAC (type: 1): 00:04:4b:a5:8a:36
[0002.815] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:a5:8a:37
[0002.821] E> “ids” doesn’t exist, creating
[0002.825] E> “connection” doesn’t exist, creating
[0002.829] E> “configs” doesn’t exist, creating
[0002.834] I> create_pm_ids: id: 3310-1000-B02-C, len: 15
[0002.839] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0002.850] I> Adding plugin-manager/ids/3310-1000-B02=/i2c@c250000:module@0x50
[0002.857] E> “i2c@c250000” doesn’t exist, creating
[0002.861] E> “module@0x50” doesn’t exist, creating
[0002.867] I> Adding plugin-manager/ids/3310-1000-B02-C
[0002.874] I> Adding plugin-manager/configs/3310-mem-type 00
[0002.879] I> Adding plugin-manager/configs/3310-power-config 00
[0002.885] I> Adding plugin-manager/configs/3310-misc-config 00
[0002.891] I> Adding plugin-manager/configs/3310-modem-config 00
[0002.897] I> Adding plugin-manager/configs/3310-touch-config 00
[0002.903] I> Adding plugin-manager/configs/3310-display-config 00
[0002.909] E> “chip-id” doesn’t exist, creating
[0002.913] I> Adding plugin-manager/chip-id/A02P
[0002.919] I> added [base:0x80000000, size:0x70000000] to /memory
[0002.924] I> added [base:0xf0200000, size:0x185e00000] to /memory
[0002.930] I> added [base:0x276600000, size:0x200000] to /memory
[0002.936] E> WARNING: Failed to pass NS DRAM ranges to TOS
[0002.941] I> Updated memory info to DTB
[0002.946] E> “reset” doesn’t exist, creating
[0002.951] E> “pmc-reset-reason” doesn’t exist, creating
[0002.956] E> “pmic-reset-reason” doesn’t exist, creating
[0002.961] I> disabled_core_mask: 0xffffff0c
[0002.971] I> Add serial number as DT property
[0002.975] I> tegrabl_load_kernel_and_dtb: Done
[0002.980] E> tegrabl_display_clear: display is not initialized
[0002.985] W> Boot logo display failed…
U-Boot 2016.07-g9c3b9a4 (May 17 2018 - 00:08:48 -0700)
TEGRA186
Model: NVIDIA P2771-0000-500
DRAM:  7.8 GiB
MMC:   Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   eth0: ethernet@2490000
Hit any key to stop autoboot:  2  1  0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
366 bytes read in 88 ms (3.9 KiB/s)
p2771-0000 eMMC boot options
1:	primary kernel
2:	xcblite kernel
Enter choice:
2:	xcblite kernel
Retrieving file: /boot/Image_xcblite
20520216 bytes read in 593 ms (33 MiB/s)
append: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2.1 androidboot.serialno=0421818031001 bl_prof_dataptr=0x10000@0x277040000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
Flattened Device Tree blob at 92000000
Booting using the fdt blob at 0x92000000
reserving fdt memory region: addr=80000000 size=10000
Using Device Tree in place at 0000000092000000, end 000000009203a15d
Starting kernel …
[    0.000000] Booting Linux on physical CPU 0x100
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.38-tegra (zjj@phoenix) (gcc version 4.8.4 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04.1) ) #4 SMP PREEMPT Tue Jul 31 10:01:56 CST 2018
[    0.000000] Boot CPU: AArch64 Processor [411fd073]
[    0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options ‘’)
[    0.000000] bootconsole [uart0] enabled
[    0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[    0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1f665c000 s31360 r8192 d30080 u69632
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 2019936
[    0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2.1 androidboot.serialno=0421818031001 bl_prof_dataptr=0x10000@0x277040000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Memory: 7976712K/8208384K available (11164K kernel code, 1819K rwdata, 5760K rodata, 1160K init, 689K bss, 166136K reserved, 65536K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000   (   246 GB)
[    0.000000]     vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000   (     8 GB maximum)
[    0.000000]               0xffffffbdc2000000 - 0xffffffbdc9da0000   (   125 MB actual)
[    0.000000]     fixed   : 0xffffffbffa7fd000 - 0xffffffbffac00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000   (    16 MB)
[    0.000000]     modules : 0xffffffbffc000000 - 0xffffffc000000000   (    64 MB)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc1f6800000   (  8040 MB)
[    0.000000]       .init : 0xffffffc001108000 - 0xffffffc00122a000   (  1160 KB)
[    0.000000]       .text : 0xffffffc000080000 - 0xffffffc001108000   ( 16928 KB)
[    0.000000]       .data : 0xffffffc00124b000 - 0xffffffc001411d18   (  1820 KB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 64.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000005] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.009688] Console: colour dummy device 80x25
[    0.014408] console [tty0] enabled
[    0.017977] bootconsole [uart0] disabled
[    0.022101] kmemleak: Kernel memory leak detector disabled
[    0.022122] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[    0.022137] pid_max: default: 32768 minimum: 301
[    0.022227] Security Framework initialized
[    0.022302] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.022316] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.023080] Initializing cgroup subsys io
[    0.023110] Initializing cgroup subsys memory
[    0.023151] Initializing cgroup subsys devices
[    0.023169] Initializing cgroup subsys freezer
[    0.023184] Initializing cgroup subsys net_cls
[    0.023203] Initializing cgroup subsys perf_event
[    0.023218] Initializing cgroup subsys net_prio
[    0.023236] Initializing cgroup subsys pids
[    0.023251] Initializing cgroup subsys debug
[    0.023632] CPU0 ipc=752
[    0.023649] CPU1 ipc=1024
[    0.023659] CPU2 ipc=1024
[    0.023668] CPU3 ipc=752
[    0.023677] CPU4 ipc=752
[    0.023689] CPU5 ipc=752
[    0.023786] ASID allocator initialised with 65536 entries
[    0.048771] tegra-id: chipid=21817.
[    0.048812] tegra-id: opt_subrevision=1.
[    0.048828] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[    0.049399] DTS File Name: arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base-xcblite.dts
[    0.049430] DTB Build time: Jul 31 2018 10:04:43
[    0.069992] CPU1: Booted secondary processor [4e0f0030]
[    0.083730] CPU2: Booted secondary processor [4e0f0030]
[    0.094903] CPU3: Booted secondary processor [411fd073]
[    0.106908] CPU4: Booted secondary processor [411fd073]
[    0.118867] CPU5: Booted secondary processor [411fd073]
[    0.119076] Brought up 6 CPUs
[    0.119155] SMP: Total of 6 processors activated.
[    0.119170] CPU: All CPU(s) started at EL2
[    0.120330] devtmpfs: initialized
[    0.144342] Initilizing CustomIPI irq domain
[    0.144805] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.146701] pinctrl core: initialized pinctrl subsystem
[    0.147238] OS set in device tree is not L4T.
[    0.147648] regulator-dummy: no parameters
[    0.147854] Initializing plugin-manager
[    0.147937] Plugin module not found
[    0.148347] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[    0.149001] node /plugin-manager/fragement@0 match with odm-data enable-denver-wdt
[    0.149708] node /plugin-manager/fragement@4 match with odm-data enable-denver-wdt
[    0.150902] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with board >=3310-1000-300
[    0.151334] node /plugin-manager/fragement-pmon-p3310-1000-300 match with board >=3310-1000-300
[    0.151647] node /plugin-manager/fragement-pmon-p3310-1000-800 match with board >=3310-1000-800
[    0.151872] node /plugin-manager/fragment-devslp@0 match with board >=3310-1000-200
[    0.152680] node /plugin-manager/fragment-p3310-c00-comm match with board >=3310-1000-800
[    0.152949] node /plugin-manager/fragment-p3310-c00-pmic match with board >=3310-1000-800
[    0.153177] node /plugin-manager/fragment-p3310-c01 match with board >=3310-1000-900
[    0.153479] node /plugin-manager/fragment-p3310-c03 match with board >=3310-1000-B00
[    0.155860] Adding domain adsp-pd to PM domain ape-pd
[    0.158669] NET: Registered protocol family 16
[    0.160325] console [pstore-1] enabled
[    0.160346] pstore: Registered ramoops as persistent store backend
[    0.160368] ramoops: attached 0x200000@0x277080000, ecc: 0/0
[    0.169320] cpuidle: using governor ladder
[    0.174872] cpuidle: using governor menu
[    0.176770] bpmp: waiting for handshake
[    0.176798] bpmp: handshake completed
[    0.176860] bpmp: synchronizing channels
[    0.176898] bpmp: channels synchronized
[    0.176915] bpmp: mail init ok
[    0.177393] vdso: 2 pages (1 code @ ffffffc001251000, 1 data @ ffffffc001250000)
[    0.177473] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.181386] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[    0.183807] tegra_powergate_init: DONE
[    0.183847] DTS File Name: arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base-xcblite.dts
[    0.183880] DTB Build time: Jul 31 2018 10:04:43
[    0.185728] Tegra reboot handler registered.
[    0.187613] Registering Tegra186 clocks (this may take a while)…done
[    0.189579] arm-smmu 12000000.iommu: probing hardware configuration…
[    0.189614] arm-smmu 12000000.iommu: SMMUv2 with:
[    0.189634] arm-smmu 12000000.iommu: 	stage 1 translation
[    0.189653] arm-smmu 12000000.iommu: 	stage 2 translation
[    0.189669] arm-smmu 12000000.iommu: 	nested translation
[    0.189691] arm-smmu 12000000.iommu: 	stream matching with 128 register groups, mask 0x7f80
[    0.189717] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[    0.189743] arm-smmu 12000000.iommu: 	64 context banks (0 stage-2 only)
[    0.189764] arm-smmu 12000000.iommu: 	Stage-1: 39-bit VA → 48-bit IPA
[    0.189783] arm-smmu 12000000.iommu: 	Stage-2: 39-bit IPA → 48-bit PA
[    0.228829] arm-smmu 12000000.iommu: registered 67 master devices
[    0.235014] iommu: Adding device 3460000.sdhci to group 0
[    0.236514] iommu: Adding device 3400000.sdhci to group 1
[    0.241616] iommu: Adding device 3507000.ahci-sata to group 2
[    0.242416] iommu: Adding device 3160000.i2c to group 3
[    0.243015] iommu: Adding device c240000.i2c to group 4
[    0.243528] iommu: Adding device 3180000.i2c to group 5
[    0.244016] iommu: Adding device 3190000.i2c to group 6
[    0.244675] iommu: Adding device 31b0000.i2c to group 7
[    0.245105] iommu: Adding device 31c0000.i2c to group 8
[    0.245536] iommu: Adding device c250000.i2c to group 9
[    0.246001] iommu: Adding device 31e0000.i2c to group 10
[    0.249133] iommu: Adding device 3210000.spi to group 11
[    0.249605] iommu: Adding device c260000.spi to group 12
[    0.250109] iommu: Adding device 3240000.spi to group 13
[    0.251200] iommu: Adding device 3100000.serial to group 14
[    0.251607] iommu: Adding device 3110000.serial to group 15
[    0.252016] iommu: Adding device c280000.serial to group 16
[    0.252380] iommu: Adding device 3130000.serial to group 17
[    0.253895] iommu: Adding device 2490000.ether_qos to group 18
[    0.254816] iommu: Adding device b000000.rtcpu to group 19
[    0.255450] iommu: Adding device c1a0000.aon to group 20
[    0.256584] Wake73 for irq=42
[    0.257018] iommu: Adding device smmu_test to group 21
[    0.257895] mc: mapped MMIO address: 0xffffff8000560000 → 0x2c10000
[    0.258002] mc: mapped MMIO address: 0xffffff8000640000 → 0x2c20000
[    0.258066] mc: mapped MMIO address: 0xffffff8000660000 → 0x2c30000
[    0.258113] mc: mapped MMIO address: 0xffffff8000fa0000 → 0x2c40000
[    0.258198] mc: mapped MMIO address: 0xffffff8000fc0000 → 0x2c50000
[    0.258261] mc-err: Set intmask: 0xf3140
[    0.258783] ecc-err: dram ecc disabled-MC_ECC_CONTROL:0x0000000c
[    0.259855] Wake76 for irq=199
[    0.259888] Wake77 for irq=199
[    0.259912] Wake78 for irq=199
[    0.259936] Wake79 for irq=199
[    0.259960] Wake80 for irq=199
[    0.259985] Wake81 for irq=199
[    0.260008] Wake82 for irq=199
[    0.260169] iommu: Adding device 3530000.xhci to group 22
[    0.260652] iommu: Adding device 3550000.xudc to group 23
[    0.261677] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    0.261719] tegra-pmc: ### PMC reset source: Power on reset
[    0.261748] tegra-pmc: ### PMC reset level: L0
[    0.261788] tegra-pmc: ### PMC reset status reg: 0x0
[    0.262204] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[    0.262252] tegra-pmc c360000.pmc: IO padctrl driver initialized
[    0.262496] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[    0.262531] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[    0.263531] iommu: Adding device 13e10000.host1x to group 24
[    0.263923] iommu: Adding device 13e10000.host1x:ctx0 to group 25
[    0.264271] iommu: Adding device 13e10000.host1x:ctx1 to group 26
[    0.264637] iommu: Adding device 13e10000.host1x:ctx2 to group 27
[    0.264972] iommu: Adding device 13e10000.host1x:ctx3 to group 28
[    0.265283] iommu: Adding device 13e10000.host1x:ctx4 to group 29
[    0.265583] iommu: Adding device 13e10000.host1x:ctx5 to group 30
[    0.265885] iommu: Adding device 13e10000.host1x:ctx6 to group 31
[    0.266375] iommu: Adding device 13e10000.host1x:ctx7 to group 32
[    0.267073] iommu: Adding device 150c0000.nvcsi to group 33
[    0.267699] iommu: Adding device 15700000.vi to group 34
[    0.268078] iommu: Adding device 15600000.isp to group 35
[    0.268490] iommu: Adding device 15210000.nvdisplay to group 36
[    0.268741] iommu: Adding device 15340000.vic to group 37
[    0.268984] iommu: Adding device 154c0000.nvenc to group 38
[    0.269217] iommu: Adding device 15480000.nvdec to group 39
[    0.269584] iommu: Adding device 15380000.nvjpg to group 40
[    0.269819] iommu: Adding device 15500000.tsec to group 41
[    0.270166] iommu: Adding device 15100000.tsecb to group 42
[    0.270949] iommu: Adding device 15810000.se to group 43
[    0.271206] iommu: Adding device 15820000.se to group 44
[    0.271435] iommu: Adding device 15830000.se to group 45
[    0.271683] iommu: Adding device 15840000.se to group 46
[    0.272281] iommu: Adding device 17000000.gp10b to group 47
[    0.274265] tegra-reset 5000000.clock: registered 193 resets.
[    0.276377] iommu: Adding device d000000.bpmp to group 48
[    0.276750] bpmp: ping status is 0
[    0.277054] bpmp d000000.bpmp: firmware tag is 83385b61e34297b2f37e76e0cd1ff81e
[    0.277517] bpmp d000000.bpmp: probe ok
[    0.279952] iommu: Adding device 2600000.dma to group 49
[    0.280934] GPIO line 457 (cam0-rst) hogged as output/low
[    0.280998] GPIO line 426 (cam0-pwdn) hogged as output/low
[    0.281073] GPIO line 424 (wifi-enable) hogged as output/high
[    0.281154] GPIO line 445 (sdmmc-wake-input) hogged as input
[    0.281259] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[    0.281386] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[    0.283635] GPIO line 315 (wifi-wake-ap) hogged as input
[    0.283747] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[    0.284750] iommu: Adding device 10003000.pcie-controller to group 50
[    0.285102] iommu: Adding device sound to group 51
[    0.287011] iommu: Adding device 3510000.hda to group 52
[    0.288265] iommu: Adding device adsp_audio to group 53
[    0.289701] iommu: Adding device 2993000.adsp to group 54
[    0.303174] vdd-ac-bat: 5000 mV
[    0.306067] vdd-1v8-ap: 1800 mV
[    0.325828] SCSI subsystem initialized
[    0.326598] usbcore: registered new interface driver usbfs
[    0.326681] usbcore: registered new interface driver hub
[    0.326853] usbcore: registered new device driver usb
[    0.332737] GPIO line 241 (touch-rail-1) hogged as output/high
[    0.333210] GPIO line 242 (touch-rail-2) hogged as output/high
[    0.333352] gpiochip_add_data: registered GPIOs 240 to 255 on device: tca9539
[    0.333812] tegra-i2c 3160000.i2c: no acknowledge from address 0x77
[    0.334175] pca953x 0-0077: failed reading register
[    0.334294] pca953x: probe of 0-0077 failed with error -121
[    0.351255] media: Linux media interface: v0.10
[    0.351421] Linux video capture interface: v2.00
[    0.357516] pps_core: LinuxPPS API ver. 1 registered
[    0.357631] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[    0.357704] PTP clock support registered
[    0.359482] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[    0.359558] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[    0.362003] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[    0.365435] GPIO line 237 (spmic_gpio_input_5) hogged as input
[    0.365747] GPIO line 238 (spmic_gpio_input_6) hogged as input
[    0.365966] gpiochip_add_data: registered GPIOs 232 to 239 on device: max77620-gpio
[    0.374246] vddio-ddr: at 1125 mV
[    0.377975] avdd_dsi_csi: 1200 mV
[    0.381976] vdd-1v8: 1800 mV
[    0.385979] vdd-3v3-sys: 3300 mV
[    0.387690] spmic-ldo0: at 1800 mV
[    0.388930] spmic-ldo1: at 800 mV
[    0.393978] vddio-3v3: 3300 mV
[    0.394988] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[    0.397313] vdd-rtc: at 800 mV
[    0.398317] avdd-ts-hv: 1800 <–> 3300 mV at 1800 mV
[    0.401306] spmic-ldo6: at 1500 mV
[    0.405301] vdd-pex-1v05: 1000 mV
[    0.406063] dvdd-pex: 1000 mV
[    0.406499] max77620 4-003c: max77620 probe successful
[    0.407412] Advanced Linux Sound Architecture Driver Initialized.
[    0.409628] en-vdd-sd: 3300 mV
[    0.413312] vdd-hdmi: 5000 mV
[    0.413578] vdd-usb0-5v: 5000 mV
[    0.413815] vdd-usb1-5v: 5000 mV
[    0.417301] en-vdd-ts-1v8: 1800 mV
[    0.421301] en-vdd-ts-hv-3v3: 3300 mV
[    0.421870] en-vdd-disp-3v3: 3300 mV
[    0.422472] en-mdm-pwr-3v7: 3700 mV
[    0.423037] en-vdd-disp-1v8: 1800 mV
[    0.423601] en-vdd-cam-hv-2v8: 2800 mV
[    0.424201] vdd-fan: 5000 mV
[    0.424366] vdd-3v3: 3300 mV
[    0.425170] dis-vdd-1v2: 1200 mV
[    0.425349] en-vdd-vcm-2v8: 2800 mV
[    0.425917] vdd-usb2-5v: 5000 mV
[    0.426069] vdd-sys-bl: 3300 mV
[    0.432540] extcon-gpio-states external-connection:extcon@1: Cable state 1
[    0.433199] clocksource: Switched to clocksource arch_sys_counter
[    0.470121] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    0.471039] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache ops by set/ways
[    0.472499] nvmap_page_pool_init: Total RAM pages: 2010562
[    0.472546] nvmap_page_pool_init: nvmap page pool size: 251320 pages (981 MB)
[    0.473026] nvmap_background_zero_thread: PP zeroing thread starting.
[    0.478498] Wake76 for irq=199
[    0.478517] Wake77 for irq=199
[    0.478533] Wake78 for irq=199
[    0.478547] Wake79 for irq=199
[    0.478562] Wake80 for irq=199
[    0.478576] Wake81 for irq=199
[    0.478591] Wake82 for irq=199
[    0.480011] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[    0.480247] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[    0.480657] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[    0.480765] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[    0.480955] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[    0.481182] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[    0.481383] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[    0.481847] isomgr_init(): iso emc max clk=0KHz
[    0.481866] isomgr_init(): max_iso_bw=0KB
[    0.482055] NET: Registered protocol family 2
[    0.482655] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[    0.482904] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    0.484009] TCP: Hash tables configured (established 65536 bind 65536)
[    0.484186] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[    0.484265] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[    0.484620] NET: Registered protocol family 1
[    0.485176] RPC: Registered named UNIX socket transport module.
[    0.485206] RPC: Registered udp transport module.
[    0.485225] RPC: Registered tcp transport module.
[    0.485244] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.485547] Trying to unpack rootfs image as initramfs…
[    0.515541] host1x 13e10000.host1x: initialized
[    0.518390] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.524228] futex hash table entries: 2048 (order: 6, 262144 bytes)
[    0.524546] audit: initializing netlink subsys (disabled)
[    0.524708] audit: type=2000 audit(0.508:1): initialized
[    0.538189] io scheduler noop registered
[    0.538464] io scheduler cfq registered (default)
[    0.544134] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    0.547061] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[    0.549303] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    0.551564] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[    0.559143] tsec 15500000.tsec: initialized
[    0.562026] tsec 15100000.tsecb: initialized
[    0.567231] nvdec 15480000.nvdec: initialized
[    0.573869] falcon 15340000.vic: initialized
[    0.576094] falcon 154c0000.nvenc: initialized
[    0.578343] falcon 15380000.nvjpg: initialized
[    0.580907] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[    0.582388] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[    0.583844] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[    0.585282] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[    0.586559] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[    0.587915] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[    0.589237] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[    0.590562] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[    0.593684] DC OR NODE connected to /host1x/sor1
[    0.594092] generic_infoframe_type: 0x87
[    0.594220] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[    0.594256] tegradc 15210000.nvdisplay: DT parsed successfully
[    0.594399] tegradc 15210000.nvdisplay: Display dc.ffffff8002320000 registered with id=0
[    0.594675] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1000000, vi_iso_bw=468750, max_bw=1000000
[    0.594738] __tegra_isomgr_register(): iso bandwidth 1000000KB is not available, client tegra_camera_ctrl
[    0.594781] misc tegra_camera_ctrl: tegra_camera_isomgr_register: unable to register to isomgr
[    0.594815] misc tegra_camera_ctrl: tegra_camera_probe: failed to register CAMERA as isomgr client
[    0.594868] tegra_camera_platform: probe of tegra-camera-platform failed with error -12
[    0.609760] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[    0.609801] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[    0.611330] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[    0.613907] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use default range
[    0.614196] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[    0.615541] kfuse 3830000.kfuse: initialized
[    0.617740] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[    0.618860] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    0.623412] console [ttyS0] disabled
[    0.623698] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra
[    0.651640] tegradc 15210000.nvdisplay: probed
[    2.650632] console [ttyS0] enabled
[    2.654420] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART
[    2.656105] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART
[    2.656396] serial-tegra 3130000.serial: RX in PIO mode
[    2.657854] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART
[    2.667145] Console: switching to colour frame buffer device 320x67
[    2.671874] brd: module loaded
[    2.678868] loop: module loaded
[    2.679474] nct1008_nct72 7-004c: find device tree node, parsing dt
[    2.679479] nct1008_nct72 7-004c: starting parse dt
[    2.679612] nct1008_nct72 7-004c: success parsing dt
[    2.679979] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[    2.695571] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[    2.717076] tmp451: Enabled overheat logging at 104.00C
[    2.717389] nct1008_nct72 7-004c: nct1008_probe: initialized
[    2.720173] THERMAL EST: found 3 subdevs
[    2.720179] THERMAL EST num_resources: 0
[    2.720185] [THERMAL EST subdev 0]
[    2.720193] [THERMAL EST subdev 1]
[    2.720199] [THERMAL EST subdev 2]
[    2.720610] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[    2.720614] THERMAL EST: thz register success.
[    2.720878] THERMAL EST: end of probe, return err: 0
[    2.720957] tegra_profiler: Branch: Dev
[    2.720960] tegra_profiler: Version: 1.117
[    2.720963] tegra_profiler: Samples version: 41
[    2.720965] tegra_profiler: IO version: 22
[    2.720981] armv8_pmu: imp: 0x41, idcode: 0x1
[    2.720986] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[    2.720993] armv8_pmu: imp: 0x4e, idcode: 0x1
[    2.720998] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2, pmu ver: 0x1
[    2.721004] armv8_pmu: imp: 0x4e, idcode: 0x1
[    2.721008] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2, pmu ver: 0x1
[    2.721013] armv8_pmu: imp: 0x41, idcode: 0x1
[    2.721017] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[    2.721021] armv8_pmu: imp: 0x41, idcode: 0x1
[    2.721025] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[    2.721029] armv8_pmu: imp: 0x41, idcode: 0x1
[    2.721033] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[    2.721461] tegra_profiler: auth: init
[    2.727081] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[    2.727098] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[    2.728623] scsi host0: tegra_ahci
[    2.729288] scsi host1: tegra_ahci
[    2.729483] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 25
[    2.729486] ata2: DUMMY
[    2.731194] spi-tegra114 3210000.spi: Static pin configuration used
[    2.731822] spi-tegra114 c260000.spi: Static pin configuration used
[    2.732366] spi-tegra114 3240000.spi: Static pin configuration used
[    2.733452] tun: Universal TUN/TAP device driver, 1.6
[    2.733456] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[    2.733742] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    2.733745] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.733791] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[    2.733794] igb: Copyright (c) 2007-2014 Intel Corporation.
[    2.735369] PPP generic driver version 2.4.2
[    2.735603] PPP BSD Compression module registered
[    2.735613] PPP Deflate Compression module registered
[    2.735662] PPP MPPE Compression module registered
[    2.735676] NET: Registered protocol family 24
[    2.735756] usbcore: registered new interface driver r8152
[    2.735794] usbcore: registered new interface driver asix
[    2.735829] usbcore: registered new interface driver ax88179_178a
[    2.735854] usbcore: registered new interface driver cdc_ether
[    2.735893] usbcore: registered new interface driver smsc75xx
[    2.735925] usbcore: registered new interface driver net1080
[    2.735950] usbcore: registered new interface driver cdc_subset
[    2.735977] usbcore: registered new interface driver zaurus
[    2.736027] usbcore: registered new interface driver cdc_ncm
[    2.736455] Wake76 for irq=199
[    2.736458] Wake77 for irq=199
[    2.736460] Wake78 for irq=199
[    2.736462] Wake79 for irq=199
[    2.736465] Wake80 for irq=199
[    2.736467] Wake81 for irq=199
[    2.736468] Wake82 for irq=199
[    2.736556] tegra-xotg xotg: usb2 phy is not available yet
[    2.737081] usbcore: registered new interface driver cdc_acm
[    2.737084] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    2.737133] usbcore: registered new interface driver usb-storage
[    2.737256] usbcore: registered new interface driver usbserial
[    2.737285] usbcore: registered new interface driver cp210x
[    2.737319] usbserial: USB Serial support registered for cp210x
[    2.737347] usbcore: registered new interface driver ftdi_sio
[    2.737369] usbserial: USB Serial support registered for FTDI USB Serial Device
[    2.737397] usbcore: registered new interface driver option
[    2.737416] usbserial: USB Serial support registered for GSM modem (1-port)
[    2.737443] usbcore: registered new interface driver pl2303
[    2.737461] usbserial: USB Serial support registered for pl2303
[    2.737790] tegra-usb-cd usb_cd: otg phy is not available yet
[    2.759722] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b a5 8a 37
[    2.760567] libphy: dwc_phy: probed
[    2.762105] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[    2.822408] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[    2.823281] __tegra_isomgr_register(): iso bandwidth 81920KB is not available, client eqos
[    2.891814] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[    2.894787] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[    2.894829] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    2.895071] i2c /dev entries driver
[    2.896104] [TC358743]: probing v4l2 sensor.
[    2.897014] tc358743_dcdz 2-000f: Failed to allocate eeprom reg map: -22
[    2.897329] tegra-i2c 3180000.i2c: no acknowledge from address 0xf
[    2.897628] i2c_wr:write reg error:reg=4,val=0
[    2.897983] gspca_main: v2.14.0 registered
[    2.898084] usbcore: registered new interface driver gspca_zc3xx
[    2.898573] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[    2.901474] FAN dev name: pwm-fan
[    2.901543] FAN:gpio request success.
[    2.901553] FAN: can’t find tach_gpio
[    2.901602] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[    2.901879] pwm_fan_driver pwm-fan: got pwm for fan
[    2.901883] pwm_fan_driver pwm-fan: tach period: 1000
[    2.902466] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[    2.902470] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[    2.902473] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[    2.902477] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[    2.902480] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[    2.902482] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[    2.902485] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[    2.902487] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[    2.902490] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[    2.902493] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[    2.903517] device-mapper: uevent: version 1.0.3
[    2.903813] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    2.904595] sdhci: Secure Digital Host Controller Interface driver
[    2.904597] sdhci: Copyright(c) Pierre Ossman
[    2.904604] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.905107] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[    2.923290] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[    2.924035] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[    2.924586] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[    2.924827] hidraw: raw HID events driver (C) Jiri Kosina
[    2.926856] usbcore: registered new interface driver usbhid
[    2.926857] usbhid: USB HID core driver
[    2.930169] tegra-i2c 3160000.i2c: no acknowledge from address 0x42
[    2.930461] ina3221x 0-0042: ina3221 reset failure status: 0xffffff87
[    2.930633] ina3221x: probe of 0-0042 failed with error -121
[    2.931046] tegra-i2c 3160000.i2c: no acknowledge from address 0x43
[    2.931320] ina3221x 0-0043: ina3221 reset failure status: 0xffffff87
[    2.931428] ina3221x: probe of 0-0043 failed with error -121
[    2.932165] nvadsp 2993000.adsp: in probe()…
[    2.933740] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[    2.933787] nvadsp 2993000.adsp: AMC/ARAM initialized.
[    2.934078] nvadsp 2993000.adsp: nvadsp_app_module_probe
[    2.948909] Denver: backdoor interface is NOT available.
[    2.951649] coresight-tmc 8030000.etf: TMC initialized
[    2.955582] coresight-tmc 8050000.etr: TMC initialized
[    2.956243] coresight-tpiu 8060000.tpiu: TPIU initialized
[    2.956995] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[    2.957696] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[    2.958326] coresight-funnel 8820000.funnel_minor: FUNNEL initialized
[    2.958894] coresight-replicator 8040000.replicator: REPLICATOR initialized
[    2.959778] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[    2.960558] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[    2.961358] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[    2.962115] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[    2.962162] Module initialized successfully
[    2.965203] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[    2.965920] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[    2.966391] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[    2.967179] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xa0000000
[    2.969455] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
[    2.969871] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011957f size=38272
[    2.970410] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    2.970485] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[    2.970566] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[    2.970615] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[    2.970659] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[    2.970706] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[    2.970756] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]=0x9180-0x9380 TX[1x384]=0x9380-0x9580
[    2.970969] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
[    2.970973] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[    2.971777] tegra-ivc ivc-b000000.rtcpu:echo@0: ivc channel driver missing
[    2.971781] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: ivc channel driver missing
[    2.971783] tegra-ivc ivc-b000000.rtcpu:mods@32c0: ivc channel driver missing
[    2.971786] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivc channel driver missing
[    2.971789] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivc channel driver missing
[    2.971792] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channel driver missing
[    2.971794] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: ivc channel driver missing
[    2.971831] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4 sha1=a8b1ecdd9615cd817a56df035be363fce3b0b88f
[    2.978134] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[    2.979317] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[    2.979474] camchar: rtcpu character device driver loaded
[    2.987311] tegra186-aondbg aondbg: aondbg driver probe() OK
[    2.987965] register_ari_mca_banks: Registered MCA ROC:IOB
[    2.988416] register_ari_mca_banks: Registered MCA ROC:CCE
[    2.989552] tegra18-bridge 2390000.axi2apb: bridge probed OK
[    2.989596] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[    2.989631] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[    2.989660] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[    2.989691] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[    2.989731] tegra18-bridge 2100000.axip2p: bridge probed OK
[    2.989766] tegra18-bridge 2110000.axip2p: bridge probed OK
[    2.989796] tegra18-bridge 2120000.axip2p: bridge probed OK
[    2.989828] tegra18-bridge 2130000.axip2p: bridge probed OK
[    2.989868] tegra18-bridge 2140000.axip2p: bridge probed OK
[    2.989900] tegra18-bridge 2150000.axip2p: bridge probed OK
[    2.989935] tegra18-bridge 2160000.axip2p: bridge probed OK
[    2.989968] tegra18-bridge 2170000.axip2p: bridge probed OK
[    2.990005] tegra18-bridge 2180000.axip2p: bridge probed OK
[    2.990038] tegra18-bridge 2190000.axip2p: bridge probed OK
[    2.990114] **** A57 ECC: Enabled
[    2.990118] tegra18_a57_serr_init: on CPU 4 a A57 Core
[    2.990314] parse_throttle_dt_data: Num cap clks = 4
[    2.990319] parse_throttle_dt_data: clk=mcpu type=1
[    2.990321] parse_throttle_dt_data: clk=bcpu type=2
[    2.990337] parse_throttle_dt_data: clk=gpu type=4
[    2.990339] parse_throttle_dt_data: clk=emc type=3
[    2.991135] tegra_throttle_probe: probe successful. #cdevs=4
[    2.991260] tegra18x_actmon d230000.actmon: in actmon_register()…
[    3.000715] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[    3.002118] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[    3.021255] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[    3.021769] sdhci-tegra 3400000.sdhci: Got CD GPIO
[    3.021836] sdhci-tegra 3400000.sdhci: Got WP GPIO
[    3.022005] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[    3.022072] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 256
[    3.022574] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[    3.027351] mmc0: MAN_BKOPS_EN bit is not set
[    3.035964] mmc0: Skipping tuning since strobe enabled
[    3.045663] mmc0: periodic cache flush enabled
[    3.045679] mmc0: new HS400 MMC card at address 0001
[    3.046374] mmcblk0: mmc0:0001 032G34 29.1 GiB
[    3.046617] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[    3.046857] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[    3.047086] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[    3.049039]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29
[    3.057250] ata1: SATA link down (SStatus 0 SControl 300)
[    3.069403] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[    3.081726] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[    3.282571] mmc1 tuning done saved tap delay=63
[    3.282580] mmc1: hw tuning done …
[    3.282595] mmc1: tuning_window[0]: 0xffffffff
[    3.282603] mmc1: tuning_window[1]: 0xfffff8ff
[    3.282609] mmc1: tuning_window[2]: 0xff8fffff
[    3.282664] mmc1: tuning_window[3]: 0x7fffffff
[    3.282671] mmc1: tuning_window[4]: 0x0
[    3.282677] mmc1: tuning_window[5]: 0x0
[    3.282684] mmc1: tuning_window[6]: 0x0
[    3.282692] mmc1: tuning_window[7]: 0x0
[    3.282696] sdhci: Tap value: 63 | Trim value: 5
[    3.282703] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[    3.294678] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[    3.294774] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[    4.502539] tegradc 15210000.nvdisplay: fb registered
[    4.509637] PD DISP0 index2 UP
[    4.516092] PD DISP1 index3 UP
[    4.520691] PD DISP2 index4 UP
[    4.526659] Parent Clock set for DC plld2
[    4.539094] tegradc 15210000.nvdisplay: hdmi: pclk:230092K, set prod-setting:prod_c_300M
[    4.567866] tegra-se-nvhost 15810000.se: initialized
[    4.582617] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[    4.617065] tegra-se-nvhost 15820000.se: initialized
[    4.631835] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[    4.647720] tegra-se-nvhost 15830000.se: initialized
[    4.661677] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[    4.677721] tegra-se-nvhost 15840000.se: initialized
[    4.693256] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[    4.711778] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[    4.729467] cpufreq: platform driver Initialization: pass
[    4.736476] tegra_cluster_clk e090000.cluster_clk_priv: in probe()…
[    4.744320] tegra_cluster_clk e090000.cluster_clk_priv: passed
[    4.750694] tegradc 15210000.nvdisplay: blank - normal
[    4.751119] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[    4.751131] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[    4.751199] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2cb094
[    4.751204] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[    4.753722] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[    4.754808] tegra186-padctl 3520000.pinctrl: VBUS over-current detection enabled
[    4.756246] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[    4.756941] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 3 not supported
[    4.760267] cpuidle: Initializing cpuidle driver init for Denver cluster
[    4.760507] cpuidle: Initializing cpuidle driver init for A57 cluster
[    4.762954] tachometer tegra-tachometer: Tachometer driver tegra-tachometer registered
[    4.762964] Tachometer driver initialized with pulse_per_rev: 2 and win_len: 2
[    4.766175] tegradc 15210000.nvdisplay: blank - powerdown
[    4.767924] tegra210_adsp_audio_platform_probe: platform probe started
[    4.773488] tegra210-adsp adsp_audio: Default param-type to BYTE for mp3-dec1
[    4.773741] tegra210-adsp adsp_audio: Default param-type to BYTE for spkprot
[    4.774051] tegra210-adsp adsp_audio: Default param-type to BYTE for src
[    4.774327] tegra210-adsp adsp_audio: Default param-type to BYTE for aac-dec1
[    4.774630] tegra210-adsp adsp_audio: Default param-type to BYTE for aec
[    4.774641] tegra210-adsp adsp_audio: adma channel page address dt entry not found
[    4.774643] tegra210-adsp adsp_audio: using adma channel page 0
[    4.783182] tegra210_adsp_audio_platform_probe probe successfull.
[    4.783184] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[    4.783529] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[    4.791504] OPE platform probe
[    4.791683] OPE platform probe successful
[    4.837083] PD DISP2 index4 DOWN
[    4.837316] PD DISP1 index3 DOWN
[    4.837483] PD DISP0 index2 DOWN
[    4.845870] tegradc 15210000.nvdisplay: unblank
[    4.845902] PD DISP0 index2 UP
[    4.847665] PD DISP1 index3 UP
[    4.848467] PD DISP2 index4 UP
[    4.849731] Parent Clock set for DC plld2
[    4.855313] tegradc 15210000.nvdisplay: hdmi: pclk:230092K, set prod-setting:prod_c_300M
[    4.870282] random: nonblocking pool is initialized
[    4.903248] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping ok
[    4.903523] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping ok
[    4.903738] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping ok
[    4.903935] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mapping ok
[    4.904118] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mapping ok
[    4.904302] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mapping ok
[    4.904537] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mapping ok
[    4.904719] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mapping ok
[    4.904911] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mapping ok
[    4.905086] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 mapping ok
[    4.905352] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF11 <-> ADMAIF11 mapping ok
[    4.905579] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF12 <-> ADMAIF12 mapping ok
[    4.905768] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF13 <-> ADMAIF13 mapping ok
[    4.905965] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF14 <-> ADMAIF14 mapping ok
[    4.906161] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF15 <-> ADMAIF15 mapping ok
[    4.906332] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF16 <-> ADMAIF16 mapping ok
[    4.906534] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF17 <-> ADMAIF17 mapping ok
[    4.906745] tegra-
Hi, what’s this “And if we do 1.8v to 3.3v change also will affect HDMI” ? After revamped, what’s the shcematic difference to dev kit then?
