I don’t know how to access the micros sd card. Here’s output from “dmesg --follow” while I remove / install sd card.
[41796.967039] rtl_usb:rtl_usb_resume [rtl_usb]:<10000-1> Too short packet from bulk IN! (len: 44)
[42306.376098] usb 2-4: USB disconnect, device number 35
[42306.376115] usb 2-4.1: USB disconnect, device number 36
[42306.381767] usb 2-4.3: USB disconnect, device number 37
[42306.684470] usb 2-4: new SuperSpeed USB device number 38 using tegra-xusb
[42306.711065] usb 2-4: New USB device found, idVendor=045b, idProduct=0210
[42306.711083] usb 2-4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[42306.714793] hub 2-4:1.0: USB hub found
[42306.715207] hub 2-4:1.0: 4 ports detected
[42307.008400] usb 2-4.1: new SuperSpeed USB device number 39 using tegra-xusb
[42307.030863] usb 2-4.1: New USB device found, idVendor=045b, idProduct=0210
[42307.030878] usb 2-4.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[42307.035281] hub 2-4.1:1.0: USB hub found
[42307.035706] hub 2-4.1:1.0: 4 ports detected
[42307.116271] usb 2-4.3: new SuperSpeed USB device number 40 using tegra-xusb
[42307.138493] usb 2-4.3: New USB device found, idVendor=1058, idProduct=0827
[42307.138508] usb 2-4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[42307.138519] usb 2-4.3: Product: My Passport 0827
[42307.138530] usb 2-4.3: Manufacturer: Western Digital
[42307.138535] usb 2-4.3: SerialNumber: 575848314538353935373337
[42307.144449] usb-storage 2-4.3:1.0: USB Mass Storage device detected
[42307.164041] scsi host4: usb-storage 2-4.3:1.0
[42307.168760] usb 2-4.1: usb_suspend_both: status 0
[42308.196682] scsi 4:0:0:0: Direct-Access WD My Passport 0827 1012 PQ: 0 ANSI: 6
[42308.199077] sd 4:0:0:0: [sdc] 1953458176 512-byte logical blocks: (1.00 TB/931 GiB)
[42308.200342] sd 4:0:0:0: [sdc] Write Protect is off
[42308.200493] sd 4:0:0:0: [sdc] Mode Sense: 47 00 10 08
[42308.201089] sd 4:0:0:0: [sdc] No Caching mode page found
[42308.201239] sd 4:0:0:0: [sdc] Assuming drive cache: write through
[42308.639679] scsi 4:0:0:1: Enclosure WD SES Device 1012 PQ: 0 ANSI: 6
[42308.849822] sdc: sdc1
[42308.855978] sd 4:0:0:0: [sdc] Attached SCSI disk
[42310.583814] usb 2-1: usb_suspend_both: status 0
[42315.471585] usb 2-1: usb_suspend_both: status 0
I’ve tried inserting the card several time. I just tried sudo fdisk -l, and I see /dev/mmcblk0, entries from /dev/mmcblk0p1 to /dev/mmcblk0p42, /dev/mmcblk0boot1, and /dev/mmcblk0boot0. I just took the card out again, and the KOOTION micro SDXC 64 GB.
I have a nano sitting here, that I have never turned on yet. Can you give me instructions on turning it on, hooking it up. P.S. Also, I see in the box provided to me, there’s a USB memory card reader that has micro SD card. Let me try that first…
OK, I can see the micro SD card, a file manager popped up, and it’s empty, 64GB. That makes sense. So, I guess the AXG reader is faulty, or I don’t insert it correctly. So, I guess we can close this thread. Thank you.
I flash AGX using a cable connect to a laptop running Ubuntu, using the SDK Manager software. So I think I’m using pure jetpack, but I’m not sure how to tell. I may need to flash AGX from SD Card, does that require the on-card card reader, or can that be done using USB card reader?
