Hey fellas! So I have a host and a couple of clients, each with Omniverse installed and such. I have previously successfully connected my client devices to the host before, all in local network. After attempting to use another device as a host, I encounter this message when logging in after adding connection from the Omniverse plug-in in UE and from adding server in OV Create:
Unable to send results back to the application that initiated the authentication. This error message is expected if your client was released prior to year 2021
I have UE 4.27.2 installed, with Local Nucleus Service 2021.3.2 on all devices. And I don’t see any updates prompt for OV Create.
On the client side, I am able to access the host Nucleus via hostIP:8080 and share files with the host, viewable by other clients.
So the question becomes, why can’t I connect my apps to Nucleus?
I have opened a list of ports including 80, 8080(just in case), 3100, 3180 and 8888. To clarify, I have no background on IT so I may have done some parts excessively.
Let me know if you need anything else from me to help resolve this. Cheers!
