Unable to get SPI Master and Slave devices on Jetson GPIO
Hi @ShaneCCC! šŸ˜„
Thanks for this. Do you know how I can convert the pin values to the Board numbering e.g. those found in the 40-pin GPIO header figure @KevinFFF posted here? šŸ”¢
You can simply get a pinmux spreadsheet for their mapping.
e.g. For PIN19 of 40-pins header
=> It is labeled SPI1_MOSI from Figure 3-5.
=> And you can find the following info in Table 3-4.
=> It also can be found in AGX Orin pinmux spreadsheet as following:
