Unable to Install Isaac Sim (missing assets)
I’ve been trying to get going with Isaac Sim for a few days, and so far I can’t get it to work. After using the launcher to install Cache and set up the local Nucleus server, when I install and launch Isaac Sim, I get the “Warning: Error finding new version of Isaac Sim assets”.
I saw this “known issue” thread: Known Issue: Error checking Isaac Sim Assets
When I added the mount as described in that thread, I got a pop up error on the bottom right that says “INVALID_URI”. Now, after a PC restart, it seems like Nucleus doesn’t start properly, since I no longer see any contents inside the localhost folder and I see a popup that says “INTERNAL_ERROR” on the bottom right now.
I’m on Ubuntu 18.04 and have an RTX 3070.
Even I am facing the same issue, looking forward for the help.
My system config is Ubuntu 20.04 and RTX 3080.
Thank you.
Please see this post. You may need to do a clean install of Nucleus.
After a clean install of Nucleus, I got a bit further - I got the Isaac mount showing up in Nucleus:
But when I re-launch Isaac Sim, I still get the same error:
Screenshot from 2022-03-21 20-09-11
Can I ignore this error now, because the assets were added via the mount?
Yes. You can ignore this error and uncheck the Perform Nucleus check on startup checkbox.
It didn’t work me work me, rather now everything is missing:
for me dir was bit different:
  • ~/.local/share/ov/Auth → ~/.local/share/ov/data/Auth
  • ~/.local/share/ov/server → ~/.local/share/ov/data/server
  • ~/.local/share/ov/tagging_service → ~/.local/share/ov/data/tagging_service
Any suggestions would be of great help on what am I doing wrong.
Thank you
What worked for me in that situation is uninstalling the local nucleus server through the “hamburger” menu here, and then setting up a new local server:
Thank you, the main issue was following settings from text in Setup FAQ page:
Type: Amazon S3
Host: ov-isaac.s3.us-west-1.amazonaws.com
Service: s3
Redirection: http://dpcil1p2xgdf8.cloudfront.net
but when i changed to below it worked:
Type: Amazon S3
Host: d28dzv1nop4bat.cloudfront.net
Service: s3
Redirection: https://d28dzv1nop4bat.cloudfront.net
