I analyzed the logs using the --vv option. The analysis compares the successful save of a USD file on the localhost Nucleus of the local machine and the failed save of a USD file on the Nucleus on AWS. Is it possible to start the server with the verbose option as well?
When the write is successful, writeFile() seems to be executed three times as shown below:
$ grep writeFile log_OK.txt | grep -v "cube.usd.png"
2025-06-05 04:31:20 [60,278ms] [Verbose] [omni.client.plugin] Tick: core: Request 1256: writeFile(omniverse://localhost/Users/sho2125/cube.usd) starting
2025-06-05 04:31:20 [60,280ms] [Verbose] [omni.client.plugin] Tick: core: Request 1256: writeFile(omniverse://localhost/Users/sho2125/cube.usd) returned Ok (version '16390', 492 bytes)
2025-06-05 04:31:20 [60,287ms] [Verbose] [omni.client.plugin] Tick: core: Request 1277: writeFile(omniverse://localhost/Users/sho2125/cube.usd) starting
2025-06-05 04:31:20 [60,288ms] [Verbose] [omni.client.plugin] Tick: core: Request 1277: writeFile(omniverse://localhost/Users/sho2125/cube.usd) returned Ok (version '16391', 492 bytes)
2025-06-05 04:31:20 [60,297ms] [Verbose] [omni.client.plugin] Tick: core: Request 1313: writeFile(omniverse://localhost/Users/sho2125/cube.usd) starting
2025-06-05 04:31:20 [60,299ms] [Verbose] [omni.client.plugin] Tick: core: Request 1313: writeFile(omniverse://localhost/Users/sho2125/cube.usd) returned Ok (version '16392', 6975 bytes)
When the write fails, the third writeFile() fails:
$ grep writeFile log_NG.txt
2025-06-05 04:32:20 [42,388ms] [Verbose] [omni.client.plugin] Tick: core: Request 1457: writeFile(omniverse://nucleus.mycompany-omniverse.com/Users/omniverse/cone.usd) starting
2025-06-05 04:32:20 [42,400ms] [Verbose] [omni.client.plugin] Tick: core: Request 1457: writeFile(omniverse://nucleus.mycompany-omniverse.com/Users/omniverse/cone.usd) returned Ok (version '1293', 492 bytes)
2025-06-05 04:32:20 [42,424ms] [Verbose] [omni.client.plugin] Tick: core: Request 1478: writeFile(omniverse://nucleus.mycompany-omniverse.com/Users/omniverse/cone.usd) starting
2025-06-05 04:32:20 [42,435ms] [Verbose] [omni.client.plugin] Tick: core: Request 1478: writeFile(omniverse://nucleus.mycompany-omniverse.com/Users/omniverse/cone.usd) returned Ok (version '1294', 492 bytes)
2025-06-05 04:32:20 [42,460ms] [Verbose] [omni.client.plugin] Tick: core: Request 1514: writeFile(omniverse://nucleus.mycompany-omniverse.com/Users/omniverse/cone.usd) starting
2025-06-05 04:32:22 [43,859ms] [Verbose] [omni.client.plugin] Tick: core: Request 1514: writeFile(omniverse://nucleus.mycompany-omniverse.com/Users/omniverse/cone.usd) returned Error: Access Denied (version '', 33005 bytes)
Looking at the moments before and after the third writeFile():
2025-06-05 04:32:20 [42,460ms] [Verbose] [omni.client.plugin] Tick: core: Request 1509: Writing omniverse://nucleus.mycompany-omniverse.com/Users/omniverse/cone.usd
2025-06-05 04:32:20 [42,460ms] [Verbose] [omni.client.plugin] Tick: nucleus_connection: Creating LFT pool https://nucleus.mycompany-omniverse.com:443/omni/lft
2025-06-05 04:32:22 [43,848ms] [Verbose] [omni.client.plugin] Tick: nucleus_connection: << path /Users/omniverse/cone.usd failing due response 403
2025-06-05 04:32:22 [43,859ms] [Info] [omni.client.plugin] Tick: provider_nucleus: Failed omni1CreateAsset(omniverse://nucleus.mycompany-omniverse.com/Users/omniverse/cone.usd):
2025-06-05 04:32:22 [43,859ms] [Verbose] [omni.client.plugin] Tick: core: Request 1509: Writing omniverse://nucleus.mycompany-omniverse.com/Users/omniverse/cone.usd returned Error: Access Denied
2025-06-05 04:32:22 [43,859ms] [Verbose] [omni.client.plugin] Tick: core: Request 1514: Stopped
2025-06-05 04:32:22 [43,859ms] [Verbose] [omni.client.plugin] Tick: core: Request 1509: move-overwrite(file:/C:/Users/user/AppData/Local/Temp/omni-usd-resolver.32736.3.usd => omniverse://nucleus.mycompany-omniverse.com/Users/omniverse/cone.usd) returned Error: Access Denied during copy
2025-06-05 04:32:22 [43,859ms] [Verbose] [omni.client.plugin] Main: core: Request 1516: delete(file:/C:/Users/user/AppData/Local/Temp/omni-usd-resolver.32736.3.usd) starting
2025-06-05 04:32:22 [43,860ms] [Verbose] [omni.client.plugin] Tick: core: Request 1516: delete(file:/C:/Users/user/AppData/Local/Temp/omni-usd-resolver.32736.3.usd) returned Ok
2025-06-05 04:32:22 [43,860ms] [Info] [omni.usd] USD saving failed
A 403 response is returned for writeFile(omniverse://nucleus.mycompany-omniverse.com/Users/omniverse/cone.usd). It is strange that the first and second attempts succeeded.
Between the second and third writeFile():
2025-06-05 04:32:20 [42,436ms] [Verbose] [omni.client.plugin] Tick: nucleus_connection: 22332: send {"command":"list2","id":54,"path":"/Users/omniverse/"}
The list command is issued, and the response is:
{"status":"OK","ts":{"omni_server_out_ts":1749097940129937},"entries":[{"path":"/Users/omniverse/Collected_test/","branch":"default","acl":["admin","write","read"],"created_timestamp":1748253859,"modified_timestamp":1748253859,"path_type":"folder","empty":false,"mounted":false,"created_by":"omniverse","modified_by":"omniverse"},{"path":"/Users/omniverse/cone.usd","branch":"default","etag":"1294","acl":["admin","write","read"],"created_timestamp":1749097940,"modified_timestamp":1749097940,"path_type":"asset","size":492,"empty":false,"mounted":false,"created_by":"omniverse","modified_by":"omniverse","hash_type":"sha-256-flat","hash_value":"909264d2a71592ca8c44e4a7507973d231bc90b3a1390247c8f78ef11de50ce4","hash_bsize":1048576,"checkpointed":true,"transaction_id":1299,"checkpoint_count":2},{"path":"/Users/omniverse/kit107test.usd","branch":"default","etag":"1285","acl":["admin","write","read"],"created_timestamp":1749017778,"modified_timestamp":1749017778,"path_type":"asset","size":492,"empty":false,"mounted":false,"created_by":"omniverse","modified_by":"omniverse","hash_type":"sha-256-flat","hash_value":"83b0d49f9760504b52f7d7e70211f4bd9cd4c120afa2e205767f01085b4900dd","hash_bsize":1048576,"checkpointed":true,"transaction_id":1292,"checkpoint_count":1},{"path":"/Users/omniverse/test.usd","branch":"default","etag":"14","acl":["admin","write","read"],"created_timestamp":1748252279,"modified_timestamp":1748252279,"path_type":"asset","size":492,"empty":false,"mounted":false,"created_by":"omniverse","modified_by":"omniverse","hash_type":"sha-256-flat","hash_value":"909264d2a71592ca8c44e4a7507973d231bc90b3a1390247c8f78ef11de50ce4","hash_bsize":1048576,"checkpointed":true,"transaction_id":40,"checkpoint_count":3},{"path":"/Users/omniverse/test.usda","branch":"default","etag":"24","acl":["admin","write","read"],"created_timestamp":1748253791,"modified_timestamp":1748253791,"path_type":"asset","size":11,"empty":false,"mounted":false,"created_by":"omniverse","modified_by":"omniverse","hash_type":"sha-256-flat","hash_value":"e6de7ae142e853e8b6c65e60f0f495e81c9c3e42abbf0970ead949423023d8e1","hash_bsize":1048576,"checkpointed":true,"transaction_id":44,"checkpoint_count":1},{"path":"/Users/omniverse/test/","branch":"default","acl":["admin","write","read"],"created_timestamp":1748928236,"modified_timestamp":1748928236,"path_type":"folder","empty":true,"mounted":false,"created_by":"omniverse","modified_by":"omniverse"},{"path":"/Users/omniverse/test10.usd","branch":"default","etag":"1273","acl":["admin","write","read"],"created_timestamp":1748927079,"modified_timestamp":1748927079,"path_type":"asset","size":492,"empty":false,"mounted":false,"created_by":"omniverse","modified_by":"omniverse","hash_type":"sha-256-flat","hash_value":"909264d2a71592ca8c44e4a7507973d231bc90b3a1390247c8f78ef11de50ce4","hash_bsize":1048576,"checkpointed":true,"transaction_id":1285,"checkpoint_count":1},{"path":"/Users/omniverse/test11.usd","branch":"default","etag":"1275","acl":["admin","write","read"],"created_timestamp":1748928684,"modified_timestamp":1748928684,"path_type":"asset","size":492,"empty":false,"mounted":false,"created_by":"omniverse","modified_by":"omniverse","hash_type":"sha-256-flat","hash_value":"909264d2a71592ca8c44e4a7507973d231bc90b3a1390247c8f78ef11de50ce4","hash_bsize":1048576,"checkpointed":true,"transaction_id":1287,"checkpoint_count":1},{"path":"/Users/omniverse/test12.usd","branch":"default","etag":"1279","acl":["admin","write","read"],"created_timestamp":1748929346,"modified_timestamp":1748929346,"path_type":"asset","size":492,"empty":false,"mounted":false,"created_by":"omniverse","modified_by":"omniverse","hash_type":"sha-256-flat","hash_value":"909264d2a71592ca8c44e4a7507973d231bc90b3a1390247c8f78ef11de50ce4","hash_bsize":1048576,"checkpointed":true,"transaction_id":1290,"checkpoint_count":2},{"path":"/Users/omniverse/test2.usd","branch":"default","etag":"17","acl":["admin","write","read"],"created_timestamp":1748252678,"modified_timestamp":1748252678,"path_type":"asset","size":492,"empty":false,"mounted":false,"created_by":"omniverse","modified_by":"omniverse","hash_type":"sha-256-flat","hash_value":"909264d2a71592ca8c44e4a7507973d231bc90b3a1390247c8f78ef11de50ce4","hash_bsize":1048576,"checkpointed":true,"transaction_id":42,"checkpoint_count":2},{"path":"/Users/omniverse/test3.usd","branch":"default","etag":"46","acl":["admin","write","read"],"created_timestamp":1748474617,"modified_timestamp":1748474617,"path_type":"asset","size":492,"empty":false,"mounted":false,"created_by":"omniverse","modified_by":"omniverse","hash_type":"sha-256-flat","hash_value":"909264d2a71592ca8c44e4a7507973d231bc90b3a1390247c8f78ef11de50ce4","hash_bsize":1048576,"checkpointed":true,"transaction_id":55,"checkpoint_count":2},{"path":"/Users/omniverse/test5.usd","branch":"default","etag":"48","acl":["admin","write","read"],"created_timestamp":1748474768,"modified_timestamp":1748474768,"path_type":"asset","size":33072,"empty":false,"mounted":false,"created_by":"omniverse","modified_by":"omniverse","hash_type":"sha-256-flat","hash_value":"57fd8d020b332d5e8d0a984caaa53b61b3ff9d44125e8ff39a95b2fa02ec36b6","hash_bsize":1048576,"checkpointed":true,"transaction_id":56,"checkpoint_count":1},{"path":"/Users/omniverse/test6.usd","branch":"default","etag":"1277","acl":["admin","write","read"],"created_timestamp":1748926625,"modified_timestamp":1748929182,"path_type":"asset","size":33005,"empty":false,"mounted":false,"created_by":"omniverse","modified_by":"omniverse","hash_type":"sha-256-flat","hash_value":"33da247e4738908547d9dcd54861c2553c66a6fd6a15d3a2e70e558e574af08f","hash_bsize":1048576,"checkpointed":true,"transaction_id":1288,"checkpoint_count":3},{"path":"/Users/omniverse/test7.usd","branch":"default","etag":"1266","acl":["admin","write","read"],"created_timestamp":1748926856,"modified_timestamp":1748926856,"path_type":"asset","size":492,"empty":false,"mounted":false,"created_by":"omniverse","modified_by":"omniverse","hash_type":"sha-256-flat","hash_value":"909264d2a71592ca8c44e4a7507973d231bc90b3a1390247c8f78ef11de50ce4","hash_bsize":1048576,"checkpointed":true,"transaction_id":1281,"checkpoint_count":1},{"path":"/Users/omniverse/test8.usd","branch":"default","etag":"1269","acl":["admin","write","read"],"created_timestamp":1748926979,"modified_timestamp":1748926979,"path_type":"asset","size":492,"empty":false,"mounted":false,"created_by":"omniverse","modified_by":"omniverse","hash_type":"sha-256-flat","hash_value":"909264d2a71592ca8c44e4a7507973d231bc90b3a1390247c8f78ef11de50ce4","hash_bsize":1048576,"checkpointed":true,"transaction_id":1283,"checkpoint_count":2},{"path":"/Users/omniverse/test9.usd","branch":"default","etag":"1271","acl":["admin","write","read"],"created_timestamp":1748927006,"modified_timestamp":1748927006,"path_type":"asset","size":492,"empty":false,"mounted":false,"created_by":"omniverse","modified_by":"omniverse","hash_type":"sha-256-flat","hash_value":"909264d2a71592ca8c44e4a7507973d231bc90b3a1390247c8f78ef11de50ce4","hash_bsize":1048576,"checkpointed":true,"transaction_id":1284,"checkpoint_count":1},{"path":"/Users/omniverse/testsuccess.usd","branch":"default","etag":"1291","acl":["admin","write","read"],"created_timestamp":1749097546,"modified_timestamp":1749097546,"path_type":"asset","size":492,"empty":false,"mounted":false,"created_by":"omniverse","modified_by":"omniverse","hash_type":"sha-256-flat","hash_value":"909264d2a71592ca8c44e4a7507973d231bc90b3a1390247c8f78ef11de50
And, I have something to worry about an issue:
2025-06-05 04:32:22 [43,859ms] [Verbose] [omni.client.plugin] Tick: core: Request 1514: writeFile(omniverse://nucleus.dentsusoken-omniverse.com/Users/username/cone.usd) returned Error: Access Denied (version ‘’, 33005 bytes)
The fact that the version is an empty string ‘’ might also be an issue.
When successful, the version contains a string (revision number?).
If you know anything please let me know.
Regards,
