The info you asked has been provided in an earlier ticket here: AQR113C PHY firmware update corrupted
| Unable to connect to 10GBASE-T1, mgbe0_0, port. Link shows active even when no cables connected | 4 | 206 | January 17, 2025 | |
| AGX Orin Initial Setup | 18 | 1984 | December 29, 2022 | |
| AQR113C PHY firmware update corrupted | 22 | 3845 | July 25, 2024 | |
| DRIVE Installer failed with status 140 | 10 | 983 | September 12, 2023 | |
| No network in DRIVE OS 6.0.5 on AGX Orin | 32 | 2886 | February 10, 2023 | |
| How to directly connect two orins via 10G-BASE-T1(mebe0_0) with H-MTD lines? | 14 | 2280 | January 20, 2023 | |
| Cannot flash Drive AGX Orion | 12 | 1253 | April 20, 2023 | |
| Install DRIVE OS with SDK Manager :Failed to bind partitions | 18 | 691 | May 30, 2024 | |
| Flashing Drive AGX Orin fails | 42 | 2715 | August 3, 2023 | |
| Screen black out in Drive AGX Orin | 13 | 116 | January 14, 2026 |
