I imported a level and level sequence into omniverse and hit the play button. The animation plays the first 5 seconds on repeat for the length of the animation instead of playing the entire animation. How would I go about setting up the animation to work from start to finish or is there a max animation length? Again, this animation is 1 minute in length but only plays the first 5 seconds.
Hi kcypher1,
Thanks for bringing this to our attention. I’ll run this by the devs and get an answer for you.
There is no maximum animation length, so I don’t think that’s the issue. Please ensure that your Level Sequence is setup to AutoPlay in the details panel. Also, check that the Level Sequence start/stop (green and red) bars encompass the whole sequence that you’re looking to export.
Without more information that’s all I can think of at the moment that might be the issue. If you’d like to share your content with us as a repro, then I’d love to take a look at it. Thanks for reporting your issue!
