- Our SSD doesn’t have SUSCLK in pin 68 but there is a SUSCLK pin connected (shown in the reference design from NVIDIA as below). Can I place NC on pin 68 of J11 directly? Any concerns?
- We are confused with the difference between your reference design guide and schematic checklist. In your reference design**, P3768-A04 Jetson Orin NX Carrier Board** ,you pull up the I2C and NC the resistor, which means no pull ups, and on checklist “shows that “do not have pull-ups on the carrier board since the devices are pulled to 3.3V on the module with 2.2kohm resistors ”. What does the devices you mean here? I am confused if we need to add pull up resistor next to I2C or not, and so does the value of the resistor that populate on the board.
- I am not sure that what does PCIE[1:0] point out? Does it include PCIE1(picA) only? Or contain PCIE0 (pic B)as well
4.following the question 3, how can I deal with pin 174, pin 172, pin 169, pin 167 if I don’t’ need to use them? Can I left them unconnected as well?Thanks
Please post to Orin nano zone next time.
- It depends on your SSD device. If SUSCLK pin is not used, you can put it NC. Not sure about your device concern.
- Just the meaning of words. No pull-up is needed.
- Where is the “PCIE[1:0]” you mentioned?
- Leave them unconnected.
In your Jetson Orin NX Series and Jetson Orin Nano Series Product Design Guide page87 Table 14-1
That’s a typo which should be PCIE[3:0].
I didn’t find PCIE3:0_WAKE. Please provide all PCIE pin numbers which belongs to PCIE[3:0]_CLK/RST/CLKREQ/WAKE specifically. Thanks.
Sorry for the late response, have you managed to get issue resolved or still need the support? Thanks
