USD access from nucleus Server denied
Hi Support Team,
I have a problem with the access of USD files from a local Nucleus Server instance.
The curiosity is that some files are accessable and some others stored in the same directory not.
I checked the permissions, but I can’t see any difference.
The Following errors appear:
2025-01-15 13:35:37 [15,940ms] [Info] [carb.omniclient.plugin] Tick: provider_nucleus: Failed omni1ReadAssetVersion(omniverse://localhost/Projects/TK/usd/tk_library/Type1_D175_T2.usd): DENIED
2025-01-15 13:35:37 [15,879ms] [Warning] [omni.usd] Warning: in _ReportErrors at line 2890 of W:\ac88d7d902b57417\USD\pxr\usd\usd\stage.cpp – In </World/Components/Type1_D175_T2_19>: Could not open asset @omniverse://localhost/Projects/TK/usd/tk_library/Type1_D175_T2.usd@ for reference introduced by @omniverse://localhost/Projects/TK/usd/clash_det/composed_stage_v2_0.usda@</World/Components/Type1_D175_T2_19>. (recomposing stage on stage @omniverse://localhost/Projects/TK/usd/clash_det/composed_stage_v2_0.usda@ <00000239333F1010>)
Thanks for your feedback
It sounds like this file “Type1_D175_T2.usd” is being LOCKED by this file “composed_stage_v2_0.usda” because you have referenced it and maybe have it open? Try quitting ALL kit apps and logging off and logging on again and just try to open “Type1_D175_T2.usd”
