Usd Composer Extension (Mdl To USD)
Hell,
i have seen there is an extension called MDL to USD Converter.
This extension has no documentation on how to used it.
Can any one link me to some docs ?
Thank you.
This is a built in core extension, that simply supports MDL. Any mdl can be saved as a usd as normal. What are you trying to do specifically ? You can start a new usd file, drag in or create some new mdl materials, and then just save the usd file.
Hey thank you for the quick response !
Im trying to create a scene in the composer and then imported in unity.
But because MDL is not supported by unity USD importer (also tried omniverse connecter in only support OmniPBR and Glass), i thought maybe i can export the MDL materials as USD and that could works ?
Thank you.
Well I would find out what materials are supported by the Unity USD Importer, for both native and Omniverse, and then make sure you are using those types in USD Composer.
