Omniverse USD Composer
Greetings, The Omniverse USD Composer is not recognizing my USD files I export from IClone 8. When I select Import the USD files do not show, When I try to send to server it says the file name either does not exist, or I’m not connected to Ominverse, or my motions are not correct. What am I doing wrong I just want to export my files from IClone to Composer
Can you attached the usd file here so we can have a look ? Have you tried opening the files in another USD program ?
You don’t want to use “Import” for usd files. Just “File > Open”. If that does not work there may be a compatibility issue.
