Can't import pointcloud USD file into USD Composer
I am having issues importing a pointcloud usd file into usd composer, it stays stuck on the loading screen. I am trying to load a scan of a factory floor to create a digital twin of said factory, but the scan itself won’t load. It was taken on a NavVis scanner and converting into a pointcloud USD file.
I’m using the Omniverse developer kit, see details in attached screenshot:
I am trying to load the file into USD Composer and this is what shows up, it just stays loading and nothing comes into the scene:
I have tried loading both the USD and .e57 versions of the same point cloud file and neither works, see details of file sizes in screenshot below:
I hope this information can give you more insight into the issue?
Can you send us the point cloud please?
See attached the usd file:
KR+11.usd
I have checked the point cloud workflow and it seems fine. I am able to import any of my 10 test point clouds which are the .e57 format. I just double click on them and they import fine in your version of Composer, 2023.2.5. Can you try another smaller point cloud please? Is it really big?
Hi Richard,
I can try a smaller one and see if that works. Do you think it could be issues with my computer rather than composer? These are its specs if that helps:
OS Name Microsoft Windows 11 Home
Version 10.0.26100 Build 26100
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name DESKTOP-QIEJ71N
System Manufacturer Gigabyte Technology Co., Ltd.
System Model B560M DS3H V2
System Type x64-based PC
System SKU Default string
Processor 11th Gen Intel(R) Core™ i7-11700F @ 2.50GHz, 2496 Mhz, 8 Core(s), 16 Logical Processor(s)
BIOS Version/Date American Megatrends International, LLC. F7 GK, 31/03/2022
SMBIOS Version 3.3
Embedded Controller Version 255.255
BIOS Mode UEFI
BaseBoard Manufacturer Gigabyte Technology Co., Ltd.
BaseBoard Product B560M DS3H V2
BaseBoard Version x.x
Platform Role Desktop
Secure Boot State On
PCR7 Configuration Elevation Required to View
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume3
Locale United Kingdom
Hardware Abstraction Layer Version = 10.0.26100.1
Username DESKTOP-QIEJ71N\AMC_VR_PC_1
Time Zone GMT Standard Time
Installed Physical Memory (RAM) 16.0 GB
Total Physical Memory 15.9 GB
Available Physical Memory 2.46 GB
Total Virtual Memory 23.4 GB
Available Virtual Memory 1.32 GB
Page File Space 7.52 GB
Page File C:\pagefile.sys
Kernel DMA Protection Off
Virtualisation-based security Running
Virtualisation-based security required security properties
Virtualisation-based security available security properties Base Virtualisation Support, Secure Boot, UEFI Code Readonly, SMM Security Mitigations 1.0, Mode Based Execution Control, APIC Virtualisation
Virtualisation-based security services configured
Virtualisation-based security services running
App Control for Business policy Enforced
App Control for Business user mode policy Off
Automatic Device Encryption Support Elevation Required to View
A hypervisor has been detected. Features required for Hyper-V will not be displayed.
Hey @aoife.odoherty
Thanks for sending your specs, can you also include which GPU you have?
We need your GPU information. Also you only have 16GB of system ram installed. That will be an issue as well.
