i took a SD Card from a jetson nano that work completely fine and put it into a brand new Jetson Nano (both Dev-Kits 4GB Version).
The new Jetson Nano would not boot at all.
When i change the SD-Card back it works just fine.
I tried with another brand new Jetson Nano Dev-Kit. Same issue.
I flashed a new sd-card with a complete new jetson-nano-jp451-sd-card-image.zip
Plugged it into the newer Jetson Nano Dev-Kit.
Did a complete boot. Did a complete system configuration (including "delete un-used bootloader partitions " (QSPI Image (MaxSPI) “After this installation this SD-Card will no loner work with the older QSPI from JP 4.4”.)
Did a system reboot. Plugged the new SD-Card off and put my sd-card in. It worked.
However the new SD-Card does not work with another new jetson nano.
How can i work with my SD-Card-Image with a brand new system? I think I compiled something (opencv wth cuda) agaings JP 4.4 so i think i need the newer JP. Or is there an easy way to update a new to the necessary JP-Version?
