Is there a way to tell definitively whether a particular board has been impacted by a PCN? The documentation states “PCN X may affect part numbers 699-83310-XXXX-D02”. Reading the eeprom one can get a hardware revision letter, i.e. I can determine a board is D02-K for instance, but is there any mapping that exists between the revision letters and the PCN? I have a customer that wants to prove the OTA JetPack update implementation works on all fielded variants.
Hi, you can only get the affected part numbers in PCN file and compare that to the board revision in hand.
