I noticed on the bottom of Exchange tab in Create, there are some Content Packs, so I installed them (all 6). Some of these files are huge, but I don’t know where they installed to.
I open up Create after installing, and I don’t see any difference vs what I had seen prior to downloading about 40 gigs of content.
Does Create know I installed these things?
As a feedback tip, I would have preferred to use another drive for these as my C drive is getting full.
Correction: I did notice a difference when I change tabs of the Materials. This used to take a little time to “connect” and now is much faster.
Still not sure how to see the Residential Assets installed.
Hello @DataJuggler!
When you download a Content Pack from the Exchange, if you click on the Save As button you should bring up the path where the content pack will be saved.
You can change where these packs are saved and set it to remember that path.
Let me know if this helped. I may need more information to help answer your question!
