Xavier NX SYS_RESET* assertion duration
A couple of questions regarding the SYS_RESET* pin functionality during normal operation.
  1. When used as an input to the module to power cycle the module, how long should the SYS_RESET* pin be held low before releasing it?
  2. When the SYS_RESET* pin is asserted by the carrier board during a module reset, should the VDD_IN (main power) and the POWER_EN also be OFF and driven low respectively? If yes, how is this different from just turning OFF the power (VDD_IN and POWER_EN) to the module without asserting SYS_RESET*?
  1. Its debounce time is typical 30ms.
  2. No, only asserting sys_reset* pin is necessary to implement a reset from carrier.
