Hello
I am developing carrier board for xavier nx.
I have questions on the SYS_RESET* handling
As datasheet requests (Xavier NX 1.6v) the sys_reset is used to power up the carrier board. It is connected as input to the carrier sequencer. If the sys_reset is low then carrier power rails are off.
When the carrier is up (normal state) and I want to drive the sys_reset for NX programing I will have the following situation.
- The user drives the sys_reset low
- The NX receives sys_reset low and on the same time all the carrier board power rails turn off (because this signal is input to the sequencer)
- The module does full power cycle
- The logic that drive the sys_reset* is longer functional because of power drop
My questions are:
- For NX programming should i use the SYS_RESET* indication or should i drive the power enable off and then on?
- How fast does the module trigger the SYS_RESET* low assertion
- Should I make delay on the SYS_RESET* so the sequencer will not drop all the carrier power and the NX will have the time to detect the assertion
- What is the recommeded way to enter module to SW programing state?
Thanks,
Roey
